350 swap fuel question
Old Feb 28, 2005 | 01:59 AM
wolfie104's Avatar
i have a 1994 toyota 4x4 that i put a carbed chevy 350 in. we got it fired up yesterday, but i have a question about fuel delivery. when i have the stock fuel pump connected, it puts out way tooo much fuel, and when i pull the fuse for it, it seems like its not getting enough with the mechanical pump (maybe the stock pump is restricting it ). can i leave the stock fuel pump hooked up and run a regulator? if so, what is a good regulator to use? the 350 is carbed and the toyota was 22re efi. if the stock toyota efi fuel pump is pushing around 40psi, why cant i just add a fuel regulator that regulates the fuel down to 5-9 psi on the fuel line? will this work ? what do i need to do with the mechanical chevy pump? please tell me how to do this! any help is greatly appriciated!!!
Old Feb 28, 2005 | 02:51 AM
Phssthpok's Avatar
Yes... an FPR will work just fine.
Back in tHe day I put a Holley Pro-jection TBI setup on my 383 RoadRunner, and the thing ran GREAT. Then some bat-rastard jacked it off my car, so I had to go back to a carb. All I did to keep the bowls from flooding due to the high pressure of the FI pump was add a Fuel Pressure Regulator and adjusted it for 7PSI.
WARNING... don't buy a cheep one. There are FPR's out there for use with mechanical pumps that WILL NOT HOLD FI pressures. You will probbably have to spend at least $50 to get one sturdy enough to handle FI pressures.
jbv808
Aug 6, 2021 04:47 PM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
