Engine Backfire
Old Feb 27, 2005 | 10:14 PM
jim628's Avatar
Engine Backfire
I have 97 4 cylinder 4Runnter with manual transmission. Recently I notice that
the car is backfiring a little bit. I have been reading some repair manuals and I am suspecting it has to do with EGR valve. What do you think? I am thinking may be the EGR valve is either sticky or the pipe that routes exhaust gas to the EGR valve is clogged. Contrary to my prognosis, I tested the EGR by applying vacum to the valve when the car is idling and the engine stalled and eventually died which is a correct behavior when EGR is in GOOD condition. Any comments would be appreciated. Also what would be the best cleaner to use to clean EGR valve/pipe?
Jim
Old Feb 28, 2005 | 04:00 AM
MTL_4runner's Avatar
Jim
How are the ignition components?
Plugs, cap, rotor, coil, wires, etc?
Also check the TPS.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
