How to remove speedo please
Old Mar 4, 2005 | 10:38 PM
Neil's Avatar
Hi, I am new to this forum and also new to my lovely 3.0l V6 4Runner. It is a 1993 model. Leaving for work this morning, suddenly there was a loud rattling in the dashboard and the speedo went crazy - slowing down however and it displayed the correct speed, but above 20mph and it went very loose with a lot more rattling noise. Now, I could be very wrong, but I am thinking that the speedo cable has come loose. I have searched the web for reference, and cannot find out how to access the rear of the speedo to check the cable. If anybody on here can help me I would really appreciate it. I have already made a mistake by removing the drivers side air vent to attempt access through that, and damaged the vent grills in the process.
Thanks for reading and I hope you can help,
Neil.
Old Mar 4, 2005 | 11:05 PM
Robinhood150's Avatar
I got your email Neil. I was just going to tell you to search around here, I'm sure you'll find your answer. Welcome to the board.
Old Mar 4, 2005 | 11:33 PM
FingerMan20's Avatar
I'm no tech, but I found this. Don't know if it'll help.
"Question: I have a 1990 Toyota 4x4, V6 pickup. The speedometer is bouncing and making some noise. I set in to take the dash apart to get to the back of the speedometer and quickly decided against it. I was told that I could pull the cable out of the cable housing from the transfer case end, Lube it , and slide it back in with out any problem. Thanks Is this true?
Jeff Gibson
Answer: Yes, you will need to unscrew the spedo cable from the back of the gauge cluster. Slide out the cable and lube it with 3 in one oil, then reinstall. This may help reduce the bouncing. Sometimes it is necessary to completely replace the spedo cable to repair."
I bet (if you feel handy enough)you can just meticulously disassemble the dash and get to that sucker. My bud with an '85 4Runner (Yotatech member Getitdone)took his dash all the way out and re-installed without any manual. But im sure yours is a little more tricky. Have you tried a Haynes manual? Pick one up at an Autozone or a local autoparts store if you can.
Old Mar 4, 2005 | 11:43 PM
Neil's Avatar
Many thanks - looks like I'm either going to be taking the whole interior front panels to pieces or trying to find this "transfer case" - any ideas where that is ?
Old Mar 5, 2005 | 12:13 AM
Neil's Avatar
Now I've found a bit of info from a UK Hilux site - it seems that I may need to remove both the upper and lower dash panels to get at the speedo from behind - does anybody know if this is true - I suppose I should just get stuck into it, but I would prefer to avoid any unneccessary dismantling.
Old Mar 5, 2005 | 12:18 AM
the transfer case on a truck is mounted under the truck, as part of the drivetrain consisting of the engine and transmission. i think it is on the end of the transmission, and to locate it, you could try and trace back your front driveline from your diff, if you can do that. but im just a nOOb, also.
Old Mar 5, 2005 | 12:21 AM
Originally Posted by Neil
Now I've found a bit of info from a UK Hilux site - it seems that I may need to remove both the upper and lower dash panels to get at the speedo from behind.
yea thats probaly the case... id worry about the transfer case thing if you need to replace the cable, otherwise focus on the dash dissection.
Old Mar 5, 2005 | 12:30 AM
Neil's Avatar
Thanks very much - I am going to begin dissection of the dash in a few minutes - I'll keep you posted as to it's simplicity.
Old Mar 5, 2005 | 12:34 AM
well hail yea neil, as they say in the business, GET IT DONE!!
Old Mar 5, 2005 | 12:40 AM
where are you at neil?? is it 3:44 where you are at too? cuz it is in dallas. a bit late to work on the dash to most... but PERFECT to some
Old Mar 5, 2005 | 12:48 AM
Neil's Avatar
No, I'm in the UK, so it's only 9.45 am - I'm at work, so what better time to get on with it - rather work's time than my time ! I am reading also that I may need to grease the cable, or replace it fully - but I am hoping that just pushing it back in may do the job ...
http://www.4x4wire.com/forums/showfl...ev=#Post505931
Old Mar 5, 2005 | 03:09 AM
Neil's Avatar
Right, I've now got to the back of the dash panel - this involves removing the COMPLETE dash, drivers side, passenger side and centre. I would advise starting with the passenger side, which will then make visible the screws holding the centre panel and the drivers side. There is a hidden screw behind the heating controls, top left corner. I can reach round the back and feel that the speedo cable is secure - but I did not like the idea of disconnecting the panel only to struglle with re-connecting. So, I'm going to order a new speedo cable here in the UK ( it needs to be shipped from Japan ) - approx £50, two weeks delivery - and get a local garage to change it for me !
Old Mar 5, 2005 | 06:42 AM
firemedic's Avatar
The transfercase is connected to the other end of the 4hi-4lo-2hi stick That is what makes your truck 4wd, it is connected to the back of the transmission, and the drivshafts both connect to it.
Old Sep 11, 2010 | 08:38 PM
hellfire's Avatar
Having a hard time trying to hold the cable over the socket and snap it on with my arm back there.. Any tricks?
Dieselmann
Feb 19, 2019 02:57 AM
choppe777
May 16, 2016 08:00 AM
old87yota
Sep 9, 2015 12:39 PM
gp66
Sep 7, 2015 08:29 AM
Aaron Logan
Sep 3, 2015 08:08 AM
