tons o maintenance done, and truck is running goooooooood
Old 03-06-2005, 09:03 AM
payyourtoll's Avatar
Well Dominique had a small overhaul of maintenance this weekend.
new timing belt
+ other belts (V, a/c, alt)
new water pump
new thermotstat
oil change and lube
new pcv
new fuel filter
clean and oil Amsoil filter
tranny flush
coolant flush
full lube + greasing
and to top it off a triple helping of SEAFOAM
Man, the seafoam rocks. Bamachem convinced me to do it here
She is running good and strong, hopefully my mileage will improve too.
Old 03-15-2005, 08:09 PM
photoleif's Avatar
did you do all that yourself, or have a mechanic do it? if the latter, mind if i ask what you paid? i'm looking at quite a bit of that (minus the water pump) coming up soon, and am dreading it... thx bud
Old 03-16-2005, 04:33 AM
The belts and water pump are things I would never try to do, outside of my ability. I was originally quoted $830 from my local Toyota dealer to do these two things alone. I asked if they would price-match, and they said yes. So I shopped around, basically called every dealer within 100 miles, and had the lowest quote faxed to me, it was 600. They matched it, and I had them flush the tranny for another 100.
They noticed that the thermostat was a junky off-brand and replaced it at no charge
If they are doing your timing belt, the water pump is RIGHT THERE to change out. Most places will not even charge for labor to do this, just for the part.
I did all the other stuff myself, you know, the easy stuff
Old 03-16-2005, 04:46 AM
4RunnerFever's Avatar
Feels like you have a new truck doesn't it? I love it when all required maintenance is done on my rig!
Old 03-16-2005, 04:50 AM
Originally Posted by 4RunnerFever
Feels like you have a new truck doesn't it. I love it when all required maintenance is done!
Feels damn good to have it out of the way. Hurts at first $$ tho
I am going to be towing this summer so I wanted to be as worry-free as I could
Old 03-16-2005, 06:35 AM
Beartracker's Avatar
2001 Tacoma S5 4x4 extended cab with 2.7 engine and auto transmission....Just had my transmission filter replaced and it cost me $35.00 for the gaskit and filter, about $20.00 for the new fluid and $20,00 in labor from my local mechanic....$75.00 total. Then I had him replace the fuel filter, grease and oil and oil filter changed useing Mobile one syn 5w30. Total was $60.00. New brake pads and rotors in front and adjust the back shoes (They looked like new) Labor and parts $90.00 . I pay cash and he doesn't charge me any tax. The best mechanic I have ever had . Mike
Old 03-16-2005, 06:47 AM
ugadawg95's Avatar
Dang...I got my timing belt and all of the other belts plus the water pump installed for less than $400 this was at a dealer too. They were running a special on the timing belt for $219 installed I guess things in the 'concrete jungle' are a wee bit spendy.
Jdgarrison
10-01-2015 05:22 PM
Badger62811
06-26-2015 09:26 PM
dirtrider0129
10
06-24-2015 12:24 PM
infinityisfive
06-16-2015 06:51 PM
Luke
07-08-2002 04:22 PM
Quick Reply: tons o maintenance done, and truck is running goooooooood
