- not starting
- Problems Shifting Into L4 On a 3rd Gen!
- Aftermarket leather seats
- HELP - What did I do to my Transmission?
- Underdog's performance upgrade kit
- Rear Speakers won't work
- Question about a Stealership
- Stats on my 4Runner
- New tires on stock wheels?
- 4wd conversion
- Engine bay lighting
- gear ratio? What the hell..my #s seem wrong.
- It's cherry.
- any piaa 520 series owners?
- For those who've installed FLX-210
- Replaced OME's with Cornfed
- taco dash rattle.
- stupid bearing question.
- quiet whistling noise
- Upper A Arm lift question
- Please Help! Drivability Problems
- weird interior
- front wheel bearings (timken)
- OME rear coils
- super cheap Lowfat tires
- Annoting brake squeal!
- 22R-E Exhaust Nuts Will Not Stay Tight
- question about 04 power door locks
- 3rd Gen hid retrofit
- engine skipping
- my turn for a "took my runner in the snow for the first time" thread
- 34 inch swampers
- air shocks
- Continuing brake issue...
- ISR Mod - Mid-grade fuel without ping
- Help, thinking of selling 2001 4Runner
- 32" Tires & Fuel Efficiency
- nakamichi?
- Stop/reverse to disengage??
- Tech Write-Up for Viper alarm install
- 3.0 gettin new HG's
- changed plugs and now pinging!!
- 4th gen cladding care question
- 94runner Cargo LIGHT replacement???
- deep water
- modernizing your interior
- bad gas mileage 91 4 runner
- Oil Leakage >P ???
- Toyota factory e-locker 2001
- Power Door Guts???
- Windows fogging
- So, how fast is the supercharged 3.4?
- SAS Swap 17 - 18th of this month -- Roseville CA --
- bush guard for sale
- Tranny swap?
- When is too much difference between cylinder compression
- Engine Swap
- 96 4Runner idle problems...
- 4" ifs in front what in back?
- aftermarket fender flares which ones cover the most??
- camry engine swap
- Co2 Rocks
- Bump Steer?
- can a 3rd gen axle with locker and all wiring be added to a 2nd gen
- driver's side window jerky
- How hard is it to change a clutch at home?
- I don't seem to have a fuel filter,,,,
- 94 4Runner Cargo Cover Needed???
- 85' SFA question
- for those of you with lifted trucks...
- Leather seat care
- Toyota's Valve Body problem?
- Building rear tire carrier...
- Street only tire?
- IAC valve?
- big puddles=no power steering?
- 5.29 gearing heating up?
- Low Profile Bumps + Discos... Need manual hubs??
- 4wd vacuum leak?
- Truck throwing multiple codes
- Morse ceramic brake pads
- Window stuck - no noise...
- VSC, ABS, and Lockers
- 91 Stereo replacement help needed
- 2003 V6 4WD - is 4WD supposed to be niosy?
- Sway-A-Way Warranty??
- Clunking...
- New Alternator... High output...
- aside from yotayard how do you source parts?
- do you extend warranty?
- Writeup for power window motor/regulator replacement
- Spring spacer question???
- Head Unit Install Help/Question
- DIN sized CB radio?
- site redesign preview
- body lift
- original tire sizes
- T-4 fluid question?
- grade 8 bolt?
- Jacob's Electronic ingition??
- tune up for 3.4l
- bushwacker extend-a-fender
- lift and tires
- 04 4runner stereo wiring change from 03
- Glass paks
- Cheapest downey coils
- What year roof racks fit my runner?
- Rear Window
- Sliders on the way Whoo Hoo
- Looking for MOUNTED 31x10.50 A/T type tires
- CB antenna idea.....
- Engine Squealing
- Check Engine Light: Running Rich
- Lifting
- cheap places to grab a 99+ black grill guard
- Custom rack and ISR mod pic's
- Non-Electronically Controlled 4WD
- 3.0 Head gasket blew yesterday!
- what is your high idle
- Factory Repair Manual ?
- Check out my 04 Sport stereo install
- Guess what happened to my CB Antenna!
- How to remove rubber strip
- good fog lights
- EGR valve malfunction?
- vibrating hood at high speed
- Found 85 4Runner for sale
- Dash Light problem
- help electrical!
- 7mge swap
- I wandered upon an 85 SFA
- will a 4runner tow hitch work on a taco
- How about this for a rear adjustable coil lift?
- injectore revisited
- New guy with pic
- 3000 mile road trip tomorrow
- Does Factory Service Manual = Repair Manual?
- Bg44k,...
- Quick Q about taillight color removing
- Engine ticking at about 1K RPMs
- how to improve gutless 3.0 V-6
- New flowmasters on!! Slight increase
- keyless with dome control?
- Toyota FTX - full size hybrid truck
- Rear Diff Breather height?
- Daystar bump stop size?
- 2000-2002 gauges
- Will stock Tacoma tires fit a Hilander?
- Toyoda?
- Block Heater Question
- buying an 82 yota questions
- New 2004 4Runner SE Pics
- weird noise
- New Mods: AZRAIN front skid, Wayfinder 6000
- VIN questions
- Loan came through for a 4runner
- Some questions for 4th gen 4runners
- Power Antenna fuse?
- Its all about the dubs and flames
- Can you identify these pads? (bww!)
- WALBRO Pump Installation Question
- How to order Lars Discos?
- Heres to Toyota!!
- Stuck at exit 45 I-90......HELP???
- 4Runner in the Drink
- NEED HELP to install Gadget's fuel kit ...
- wanted
- explain 4wd in 2001 limited
- leather treatment
- anyone have a stillen exhaust on their 3rd gen?
- Spark Plugs Q
- Piston slap on the iForce V8s?
- Transmission cooler?
- friends 2001 won't engage 4x4
- Thanks YotaTech! (pics)
- Dash Squeak
- Yakima Rack on 3rd Gen
- Insurance mess up
- Toyota Full size truck
- CB Antenna
- Will they fit?
- Cb
- Where does your exhaust exit?
- Alt upgrade and possible relocation
- Power Steering Leak
- second rotor cap?
- chrome
- 22r interchange with 22re
- BigBadBlue
- stock front height
- 4Runners and Taxi Cabs Don't Get Along
- got 85 manuel on CD!!
- Looking for some aftermarket tail lens.
- chevy 4.3 swap..
- Windjammers
- New Year mods: fan and alt
- '91 Stereo ?s
- Toyota OEM body parts
- springload lifters
- K&N air filter
- 2nd gen 3 inch body lift: whos done it?
- Engine cutting out
- help-shim on leaf spring
- drilled slotted brake rotors
- To those who are snorkeled...
- starter removal
- AutoCAD 3-D Model
- Why I can't use Motive's Power Bleeder And shots of my compressor
- 4th Gen. Heated mirrors
- Started my SAS YAY!
- Tour the NUMMI plant!
- Filters--air/oil
- New pics
- weber carb of fuel injection?
- rebuild or swap?
- That old engine swap thread
- Shifter bushing replacement Q
- Hi lift jack?
- aftermarket intake tube with stock airbox
- looking at buyin a taco...need advice
- Recovery Equipment
- Gotta Love It!
- bad shifting
- stock fiberglass fenders
- 4th gen auxilliary mirrors
- Tranny question....
- K&N Air Filter for my '99 4Runner 3.4L?
- few slider questions
- Cold
- Clutch questions that may sound silly....
- Finished Front and Rear Bars
- Why would anyone drill holes in a Thermostat?
- Grille inserts or cover for '99 4runner
- Brakes freezing
- New 4 Runner or Tacoma DC
- What Kind of floor jack do you use for front end???
- ABS/VSC Working Correctly?
- Stubbs Welding rock slider reveiw????
- Winch Tip
- ATS Motorsports?
- easiest and cheapest 2in lift?
- Ready to buy a 1990 4Runner. Is it a good idea ?
- Transmission ?
- 93 sr5 ext cab
- Changing Clutch Tomorrow (Long)
- Front speakers?
- 4 wheel drive acting strange
- Seat cover recomendations
- cruise control
- 3rd Gen Rear Bumper (protection) Idea
