New flowmasters on!! Slight increase
Old Jan 5, 2004 | 10:49 PM
bigKahuna's Avatar
Hey guys, got my new flowmasters on. Got the 40 series and notice a lot more sound from the outside. Its barely noticeable inside. It has a nice V8 chevy sound and really grows at 2500 rpm however at higher speeds its barely noticible at 3250 the sound dies down.
As for performance It feels like it flows smoother however it may just be because the original exhaust may have been exhausted (to many years of build up on the stock mufflers) slight increase in acceleration probably 7% its noticible believe it or not. I wish I had a Dyno to actually test them properly and give a better evaluation.
Well bought them for $125 installed however I'm not to happy about the welding job as its slightly crooked . For a guy that has a reputation for working on hot rods the quality of his work honestly sucked... but none the less it works, without leaks, perfoms and sounds good.
As for performance Its to early to tell... Right now I waisting alot of gas just reving it to 3000 rpm. I know what a poseur Yadayada.... however it just sounds to good. I sure freakd out my friend at the dealership he thought I did a V8 conversion hahaha
If you got any additional inputs please add to this as there does not appear to be to many flowmaster 40 series reports.
peace Big Kahuna
Old Jan 6, 2004 | 09:39 AM
mochoajr's Avatar
Flowmaster #
What's the part number to the muffler?
mochoajr
Old Jan 6, 2004 | 10:10 AM
cubuff4runner's Avatar
I just put the same muffler on mine last week. I agree with you about the sound. Little noise inside the vehicle and lets out a nice rumble. I noticed a slight increas in power at higher RPM's. I was charged $160 for the muffler and the pipe from almost the cat-back.
Old Jan 6, 2004 | 10:38 AM
midiwall's Avatar
Re: New flowmasters on!! Slight increase
Have you done anything to allow more air into the engine? Now that the engine can exhale better, you need to make sure that it can inhale easier as well.
Old Jan 6, 2004 | 10:55 AM
kraegelb's Avatar
I had a 40 series on my 4.3 Blazer and it sounded really good...congrats!
Old Jan 6, 2004 | 10:57 AM
SLC Punk's Avatar
I have the 60 series Flowmaster. I love it.
I was told that the 60 series was made for 6cyl and 4cyl appications. It reduces teh high-pitched raspy sound and just leaves the low rumble.
I like how I can barely hear it inside. I don't even get the dreaded drone sound that many 4Runner guys get at highway speeds.
Old Jan 7, 2004 | 10:50 PM
bigKahuna's Avatar
Flowmasters rock
Hey guys sorry the computer was down for a while
midiwall: all I did was a k&n filter swap and in the original air box got any suggestions??
Mochoajr: the part # 942441 in the delta flow 4o series
Peace to all
Big Kahuna
Old Jan 7, 2004 | 11:58 PM
midiwall's Avatar
Re: Flowmasters rock
Oh yeah man...
DECKPLATE!
But then, you have a '90.... crap. The airboxes that I've seen on that early of a rig may not allow you to cut it out. Here are a couple of pages to give you an idea of what the intent is:
http://www.toyotaoffroad.net/jnburtman/deckplate.html
https://www.yotatech.com/~corey/tech.../deckplate.htm
Old Jan 8, 2004 | 07:24 AM
saigon1965's Avatar
I think what I have is a series 50 3" cat back piping with a nice oval tip .
"Have you done anything to allow more air into the engine? Now that the engine can exhale better, you need to make sure that it can inhale easier as well."
Oh I solved the air starvation problem by adding the supercharger
Old Jan 8, 2004 | 08:14 AM
midiwall's Avatar
Originally posted by saigon1965
I think what I have is a series 50 3" cat back piping with a nice oval tip.
3"??? Wow... I originally had my free-flow installed with 3" pipe and lost a LOT of bottom end - to the point that I knew something was wrong.
Dr. Z (from the forum here) schooled me on "bigger ain't always better" and pointed me to this site:
http://www.torquetechexh.com/whichsize.htm
The short form is that I had my exhaust re-done with 2.5" pipe and the difference was incredible. Most of the low end torque was back (I expected to lose _some_) but I kept the new power boost at the 2200-3000 range.
Oh yeah, that'll do it!
Old Jan 8, 2004 | 12:27 PM
SLC Punk's Avatar
Yeah 3inch will only really help on Turbocharged engines. OUr 3.4L needs a little backpressure (expecially if you have not done the fuel mods!)
Old Jan 8, 2004 | 04:51 PM
mastacox's Avatar
I put a 2.5" 50 Series SUV on mine and installed it myself and then got it welded at a shop.
I bought the muffler and a high flow cat from Summit racing, about $70 for the muffler, $50 for the cat.
Cost about $225 total, and sounds great.
I like the sound, but only a V-8 sounds like a V-8, this is more of a high, less lopey sound. Nonetheless, sounds great and gave maybe a little performance gain.
I had to replace my exhaust because I mushed my other muffler on a monster rock, and the exhaust leaks made the thing sound like a tractor
Old Jan 8, 2004 | 09:24 PM
saigon1965's Avatar
SLC, yeah I did the fuel mods, still in the process of putting the APexi unit in, but I'll check out Dr.Z's site and see what's up.
Old Jan 9, 2004 | 12:38 AM
bigKahuna's Avatar
good tips guys
Hey I really like Coreys site
Im gonna try to upgrade lightly also I think 2 1/4 pipe is good enough as I dont want to lose low end torque I had trouble getting over a log at the obstical course in Hollister as Robinhood can attest to.
What I dont get is... why does the sound get quieter as I bring up the rpm? Its all down hill as far as the growl after 3000 rpm. however the power is still there till about 4700. I'll try to give it more air however I am fearful of losing back pressure and torque.
Peace Big Kahuna
Old Jan 9, 2004 | 05:54 AM
midiwall's Avatar
Re: good tips guys
As the RPM comes up, each individual shockwave of the combustion process is getting shorter. The shorter wave is smoother and acoustically has less "sharp edges" in it, that gives it a smoother tone. There's also less acoustic energy in each wave, hence the lower volume.
Also, there's a parallel thread happening that got to talking about pipe tuning. That could help you out as well in terms of extracting the most power possible:
https://www.yotatech.com/forums/show...threadid=24105
Old Jan 17, 2004 | 01:17 PM
mattco16's Avatar
I got a 40 series on my 22RE. Sounds good too. Like the low RPM growl it gives. ALmost sounds like a small six.
Old Jan 17, 2004 | 09:32 PM
Mike06's Avatar
How much was it? Did you buy it online? Where?
Thanks.
Old Jan 19, 2004 | 10:31 PM
bigKahuna's Avatar
Ok guys just a update
Just back again from Holister Hills and had a great day once I got to the top of the mountain it was beautiful and sunny as all of the rain clouds were under me I'll post a picture. The mountains looked like a island in the clouds... Well as for the flowmasters they growled all the way up and the final consensus is they have increased power it was very easy to climb steep angles however since getting them I have lost about 30 miles on a tank of gas from 245 to 215 and I have increased my tire width to 11.5 from a 10.5 so the exztra drag may have been due to the tires. who knows
If you have an imput please include thanks
Big Kahuna
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
the_supernerd
Oct 1, 2015 09:20 PM
dbollier123
Sep 29, 2015 05:23 PM
drifttruck
Sep 18, 2015 11:19 AM
