vibrating hood at high speed
Old Jan 6, 2004 | 11:00 AM
Beachrunner's Avatar
Seems as though there was a thread on this awhile back, but I can't seem to find it. Ever since I installed my bug shield, I get a horrible vibration in the hood up towards the hinges. Is there a fix to this problem?
Old Jan 6, 2004 | 11:04 AM
instntset's Avatar
Just wanted to chime in and say that Ive had this same problem recently as well. Mine is a 2nd gen though.
I lifted the hood to tighten up the hood mounts where they meet the hood and they were already very tight. It seems to be loose from inside where the mounts go through the firewall. Have not had the time to tear into it yet and see what is going on with mine.
Old Jan 6, 2004 | 11:14 AM
StingRay's Avatar
I've heard of this before though I really don't get much over 75 MPH with ours and haven't seen it yet myself. While surfing the net a while back I came across a guy that is an engineer that makes and sells a bolt in hood brace to eliminate the problem. Try looking for it on Google. Maybe you'll find the same site I did.
Old Jan 6, 2004 | 11:18 AM
Phil's Avatar
Mine vibrates, so did every 3rd gen I test drove, with or without bug shields. I figured it was normal.
Isn't that bad though.
Old Jan 6, 2004 | 11:33 AM
waskillywabbit's Avatar
Re: vibrating hood at high speed
I have no clue if this works, but I've seen this before...
http://www.flankersolutions.com/
Old Jan 6, 2004 | 11:50 AM
StingRay's Avatar
Yup that's the brace I've seen on the web before.
Old Jan 6, 2004 | 11:57 AM
Bennito's Avatar
I concur. Vibration wasn't noticeable until 80 or 85 prior to the bug shield. Now vibration happens at 75mph.
If anyone has tried the Flanker Solution Inc, solution, I'd be very curious to hear the results.
Old Jan 26, 2004 | 05:22 PM
CBDenver's Avatar
I'm also very interested in this site and the "fix" he sells. Is it worth $50 though? Anyone on here ordered one and tried it?
Thanks!
Old Jan 26, 2004 | 05:44 PM
Pretacopower's Avatar
Yep....mine does it too. Doesnt bother me though. Gives it a more rugged and abused look
Old Jan 26, 2004 | 07:06 PM
CLin9383's Avatar
yep mine does it too...my friend noticed it and asked "you sure that's not gonna flap up" and i said..i dunno, it hasn't so far! hahah, i'd be interested in the flanker thing also..just need to find a guinea pig!@
Old Jan 26, 2004 | 07:12 PM
Even the Tacoma's do this. Mine did and thats just the way they were designed.
Old Jan 26, 2004 | 07:34 PM
ALBPM's Avatar
I have the EGR Carbon Fiber "like" guard and it made a lot of wind noise after I installed it.
I solved mine by adjusting the hood stops in the front. Just screw them "out" a bit more. This raises the front of the hood a bit and changes the airflow.
This was the fix for my 93 Runner's problem with the back hood rattling/flapping at high speed.
Old Jan 26, 2004 | 09:57 PM
zedex's Avatar
My taco did it as well as my 68 stang. Front hood rubber adjustment cured it.
Old Jan 27, 2004 | 04:33 AM
cool, thanks... I'll have to try this after I chip all the ice and snow off.
Old Jan 27, 2004 | 06:08 AM
ALBPM's Avatar
I put up with the Hood flapping at speeds above 60mph for almost three years on my 93 Runner before a Tech at the Toyota dealer told me to turn out the Hood Stops until the rattles and flapping stops.
I had the same problem with the 02 after I put the bug guard on it. The back of the Hood started rattling until I adjused the Stops.
Old Jan 27, 2004 | 12:26 PM
rimpainter.com's Avatar
Hmmm, my 96 doesn't do it (no bug shield) but my 98 Taco did it (Toyota bug shield). Kind of annoying for a Toyota...maybe on a Jeep, but not a Toy.
Old Jan 27, 2004 | 12:37 PM
CLin9383's Avatar
yea i had no vibration until the bud shield.
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jjrbus
Jul 19, 2015 02:06 PM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
wilbertd
Jul 6, 2015 07:39 AM
