Can you identify these pads? (bww!)
Old Jan 5, 2004 | 02:27 PM
4RUNR's Avatar
Guest
Metallic? Semi? Ceramic?
New? They are only 9.2mm thick from the plate backing.
Made in Canada? Any identifies if they are quality?
Old Jan 5, 2004 | 03:24 PM
Unhappy99's Avatar
There should be a company name stamped into the back side of the backing plate. In any case, the FF pad code friction rating is desirable.
Old Jan 5, 2004 | 05:51 PM
Firefyter-Emt's Avatar
I can not quite make out the picture.. Do you have something a little bigger so I can get a better look??
Old Jan 6, 2004 | 10:04 PM
williemon's Avatar
You might try to see if a small magnet will stick to the friction material. I noticed that on a set of semi metalic that a vinyl magnet would stick whereas it would not to an organic friction material.
Old Jan 7, 2004 | 05:53 AM
4RUNR's Avatar
Guest
Nope, no sticking. I'm pretty sure they are ceramics since they are very light, barely tan color.
I put them in already, had 8mm left on old ones, and these are much firmer so they must be ceramic.
Old Jan 7, 2004 | 08:11 AM
MTL_4runner's Avatar
They are either organic or ceramic pads because even the semi-metalic you will see little shiny areas on the pads. My be would be ceramic as well since the little brown specs are not usually in a regular organic pad and those pads appear lighter in color than usual as well. Some manufacturers use different compounds so it is tough to tell for sure.
Old Jan 7, 2004 | 03:08 PM
4Paws's Avatar
I think the picture is of the Mars Rover tire grooves.
Old Jan 8, 2004 | 07:36 AM
mt_goat's Avatar
Never mind the pads what is that material they are sitting on?
Old Jan 8, 2004 | 09:15 AM
4RUNR's Avatar
Guest
An orange goat that fetches me the wrenches of course
Old Jan 8, 2004 | 12:56 PM
instntset's Avatar
Old Jan 14, 2004 | 08:01 AM
Unhappy99's Avatar
Stumbled across the answer....TS C
Trustar ( a marketing conglomerate )
Cermamic ( what the C means )
Trustar is a marketing company and doesn't manufacture anything. They rebadge and distribute.
If I were to make a slightly educated guess, I'd say these were built by Bendix.
ladybugRC
458
Aug 21, 2020 10:41 AM
user 82300
Sep 22, 2015 07:00 AM
Bill854x4
Sep 20, 2015 04:32 PM
sonorn67
Sep 19, 2015 05:39 PM
user 82300
Sep 15, 2015 05:49 AM
