Uh Oh...whats this??
Old Oct 21, 2004 | 01:33 PM
AzStorm's Avatar
A small leak of red fluid coming from somewhere on the passenger side of the motor.
It doesnt seem to be brake,clutch or power steering fluid and I cant locate where its coming from.
It shows a drip streak on the front of the front differential and leaves a drop or two as soon as I park.
What the heck is it???
Old Oct 21, 2004 | 01:39 PM
Glenn's Avatar
Coolant?
Old Oct 21, 2004 | 01:59 PM
AzStorm's Avatar
nope.Just checked.
Crap! Looks like diff.fluid
I absolutely HATE when a vehicle leaks ANYTHING!!!
Old Oct 21, 2004 | 02:22 PM
quik05's Avatar
RED sounds like auto trans fluid
Old Oct 21, 2004 | 02:35 PM
AzStorm's Avatar
It looks like ATF,but I have a 5 speed and its far forward of the gearbox.
I wonder how much of a task it is to change the gasket?
Old Oct 21, 2004 | 03:42 PM
KevyWevy's Avatar
how do you know its not coolant? how many miles does your truck have on it? has the water pump been replaced? cause mine just leaked a little bit and only sometimes, turned out to be the water pump
Old Oct 21, 2004 | 03:50 PM
superjoe83's Avatar
smell it
Old Oct 21, 2004 | 05:05 PM
AzStorm's Avatar
I know the difference between yellowish green coolant and RED oil.I dont use the red coolant.
Old Oct 21, 2004 | 05:09 PM
superjoe83's Avatar
could be ATF from your power steering, hows the fluid level? just a guess
Old Oct 21, 2004 | 05:38 PM
CynicX's Avatar
I've never seen RED diff fluid, but I'm no mechanic...all diff fluid I've ever seen starts out like typical oil color, clearish brown....ohhh and used diff fluid smells absolutely horrible...
Old Oct 21, 2004 | 05:41 PM
AzStorm's Avatar
Ive pretty much eliminated everything except the diff fluid.PS fluid is virtuall clear and the res. is full,so is the clutch,brakes.I'll have to take a closer look in the AM when its light and not raining.
Old Oct 21, 2004 | 05:43 PM
AzStorm's Avatar
I dont know why someone would use ATF for diffs but thats what it looks and smells like.I allways thought gear oil was used in diffs.
Oh well.The good news is I get my sliders welded on tommorow!!
Old Oct 21, 2004 | 06:21 PM
kyle_22r's Avatar
you might've gotten a real schmuck previous owner...
the fluid in your power steering reservoir shouldn't be clear i'd think. should be red, as it should be dextron ATF
