2000 runner 4wd fix
Old Nov 7, 2013 | 02:31 PM
Zombiepirate's Avatar
2000 runner 4wd fix
Howdy All
I have a 2000 4 runner 3.4L automatic that would not go into 4wd no light nothing. After checking this forum and reading about others that have had this problem, I proceeded to check switch's, actuator, vcsv's, vac. line's, Etc.
what I found was that the vac. line coming from the vcsv to engage 4wd had no vac. at actuator. but had vac. at vcsv, After putting compressed air to that line I have vac. at actuator 4wd go's right in, Light comes on Just as it should So I am not saying this will fix anyone else's, But it just go's to show "Check those vac. line's" Not only can you have a vac. leak
A plugged line will give you just as much trouble "Fix it by the fire Keep away the Zombies"
ACZR
Jun 23, 2015 07:55 PM
Schif
Jun 20, 2015 08:39 PM
TheManOutside
Jun 18, 2015 03:32 PM
Hbum
9
Jun 13, 2002 07:27 PM
