Transmission pan bolt torque spec ?
Old Jan 27, 2007 | 02:16 PM
alotawatts's Avatar
My service manual indicates 65 ftlbs for the transmission pan bolts.
That 'aint right is it ?
Old Jan 27, 2007 | 02:22 PM
toyotaoffroad91's Avatar
i believe it somwhere around 13 maybe even less. just snug em up then a little less than a 1/4 turn
Old Jan 27, 2007 | 02:31 PM
mt_goat's Avatar
It's 65 all right but NOT ft-lbs, it's IN-LBS. That would be 5.41 ft-lbs.
Old Jan 28, 2007 | 09:41 AM
MTL_4runner's Avatar
Ditto.....BIG difference there.
Old Mar 9, 2025 | 02:08 PM
Jettech1965's Avatar
Transmission pan bolt torque.
Please don’t torque transmission pan bolts to 65 ft./lb or even 65 in/lb. The Haynes manual specifies 3-4 ft/lb which is 36-48 in/lb. I’m not even sure why torque is specified in ft/lb when under 25 ft/lb. In/lb is a better value when torque wrenches are already dialed with in/lb and is more accurate generally.
using too high of torque on pans or valve covers will crush the gasket and render it useless when heat and oil are added to the wrinkled rubber gasket and probably cork gaskets as well.
Old Mar 12, 2025 | 06:51 AM
Jomoka's Avatar
Thanks, I think you warned them just in the nick of time.
Old Mar 12, 2025 | 06:59 AM
Discombobulated's Avatar
I just spit out my coffee
tpthomas
Mar 10, 2015 09:00 AM
dpr64
Jan 19, 2014 06:52 AM
Bruinpilot
Aug 1, 2013 02:26 PM
flashkl
Feb 18, 2009 06:26 AM
Ebin
Oct 14, 2007 11:25 AM
