Driveshaft center bearing
Old Nov 7, 2009 | 11:49 AM
team_gforce's Avatar
So I started noticing over the last month or so that there seems to be a lot of movement in the transmission/t-case shifters in my Tacoma. It is most noticeable when I hit the gas after being stopped at a stop light or when driving down a less than smooth road. Every time I hit a bump or pothole the shifters seems to jump, almost sounds like the trans shifter is going to jump positions. I started investigating under the truck today and hit all the joints with some lube. I was shaking down the driveshaft to check all the u-joints and noticed that there seems to be a lot play in the center support bearing (at least 1/2'' in all directions) This is the first vehicle I have owned with this type of bearing. Is this amount of free play normal or am I going to have to replace it?
Old Nov 8, 2009 | 02:32 PM
KrashDH's Avatar
The play is normal. The bearing is contained by a rubber "shock absorber" boot. The bearing slides over the drive shaft and that rubber bumper allows the drive shaft to move around (absorbed by the boot). You will know when the carrier bearing goes bad because there will be a squeak in sync with your rpms.
Old Nov 8, 2009 | 03:51 PM
ok thanks, no noises yet so I guess I'm good for now
Old Nov 9, 2009 | 07:27 AM
mt_goat's Avatar
Check your engine and tranny mounts.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
trailgoat
Aug 13, 2015 05:54 PM
JimiJams
Aug 7, 2015 01:36 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
