More manual hub problems...
Old Jun 26, 2004 | 10:59 PM
WSU4runner's Avatar
Ok I dont really know what's wrong with them. I probably just suck at installing stuff But when I tested them (jacked up one side and spun the wheel while in 4x2, axles and everything still spun) they didn't seem to be working right. Also, I can't seem to move the "dial" on the hub from 4x2 to 4x4. It gets stuck right in the middle and won't move.
Did I install these wrong, or are the hubs not working right. Any help is greatly appreciated.
Old Jun 27, 2004 | 05:41 AM
toy283's Avatar
Sounds to me like they were assembled/installed incorrectly, not hard to do until you get the hang of them. Remove the outer cover. Then turn the dial to 2wd and make sure that the collar inside is tucked up tight with the hub cover then reinstall. If you took the whole hub apart originally, they have to go back together in a certain way or they won't work. The FSM has a good description of how it needs to go back together. I can scan and send you the required pages if needed.
Old Jun 27, 2004 | 05:54 AM
Corey's Avatar
Co-Founder/Administrator
I have the Aisin hub PDF file here.
It is 198 kb in size.
Old Jun 27, 2004 | 11:00 PM
WSU4runner's Avatar
Will that work for Warn Premium hubs as well. Or is it strictly for Aisin??? Thanks guys for the replies!
carlspeed
Aug 23, 2015 02:59 PM
greyheadedguy
Aug 18, 2015 10:40 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
