What type of Tranny Do i Have?
Old Apr 27, 2015 | 12:05 PM
jessecain1's Avatar
Hey fella's, i have a 98 tacoma 3.4, 4wd, 5spd That wont go into any gear but 4th im thinking i need a rebuild on my transmission. Does anyone have a part number for the tranny? Also if anyone could point me in the direction of a good quality rebuild kit.
Thanks
Old Apr 27, 2015 | 12:46 PM
fierohink's Avatar
Look at the info tag on the drivers door sill. There should be a code for trans and axles. Then check marlin crawler I think they have rebuild kits. I know they sell complete transmissions.
Aside from only going into 4th why do you think the trans is shot? Has it been giving you problems? Has it been making noise? Standard transmissions can take significant abuse and still work. Generally the clutch is the weak link. Could it be possible you just fried the clutch?
Old Apr 27, 2015 | 02:12 PM
jessecain1's Avatar
Would it be the clutch if it will still go in 4th like normal?
Old Apr 27, 2015 | 03:27 PM
fierohink's Avatar
when you say goes in like normal, is that with the truck running or off? How does the pedal feel? Did anything happen before? Were you driving when it quit shifting? Or did it not go into gear when you went out to start it one day?
The info you provide the more we can help
Old May 4, 2015 | 06:07 AM
Kevin_A's Avatar
Mine would not go into 1st or reverse, at first I thought the transmission needed help.
It turned out the clutch fork was cracked and I was not getting the travel I needed to fully disengage the clutch.
You could also checked the dreaded "cracked firewall" that limits clutch pedal travel, the master cylinder and slave cylinder. One more thing, the shifter bushing could be shot, I put a new one in mine when I did the clutch fork, shifts like new now.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
1985 4Runner
Sep 30, 2015 10:17 AM
