New gears and gas milage question
Old Nov 3, 2004 | 04:38 PM
Greedy's Avatar
I just had a brand new factory rear diff put in and my gas mileage has dropped significantly (from about 240 miles a tank to about 180). Here's what I had Done:
1. Blew up the ring and pinon on my stock 4.30 elocker rear
2. Had a brand new, toyota oem rear put in - identical unit.
Is there some kind of break in period that I need to go through to get rid of some resistance? - Or - could there have been an error with the installation that is causing this. When driving though, everything feels and sounds fine, goes into 4hi/4lo and locks/unlocks perfect. Any ideas?
Old Nov 3, 2004 | 05:11 PM
User 051420's Avatar
Follow this..It's VERY important!
http://www.4crawler.com/4x4/CheapTri...ml#GearBreakin
Have you broken in your previous sets of gears? I bet that's why you've broken so many.
Old Nov 3, 2004 | 05:18 PM
Greedy's Avatar
Thanks. The only thing with that is that the rear that broke was the stock elocker that came on the truck new. The unit I put in was the identical, but completly new, rear bought from a dealership. Do you have to break in the gears on a new 4x4 when you take it off the lot? If I was supposed to I might be screwed - I have driven probably 300 miles or so as i normally do (all speeds - 20-30 minute trips).
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
