Rear end leaking.
Old Sep 24, 2014 | 02:10 PM
lump8757's Avatar
Rear end leaking.
Is there a gasket for the third member housing or will good ole RTV seal it up good enough?
Old Sep 24, 2014 | 02:55 PM
highonpottery's Avatar
if it's coming from the 3rd member-to-housing seal then yes, RTV is the preferred repair. pretty simple repair, just be careful of damaging axle seals when removing axles to pull your diff off. if you're draining and servicing the diff it might not be a bad idea to replace drain plug with magnetic low-profile version. good luck!
Old Sep 24, 2014 | 03:02 PM
lump8757's Avatar
I got tired of waiting for a reply and went ahead and tore into it after I realized I've done this repair 100 times already a work. No biggie. Thanks for the reply though.
Old Sep 24, 2014 | 03:23 PM
JasonYota's Avatar
If you have done this repair 100's of times why did you ask if there is a gasket??
Old Sep 24, 2014 | 04:32 PM
lump8757's Avatar
Cause the rear end on this is like the rear end on the trucks I work on for a living.....so I haven't really done one on a 4Runner till now.
Old Sep 24, 2014 | 11:54 PM
wyoming9's Avatar
Red face
Myself I would want to know why it started leaking??
I see mechanics like you all the time throw something different at them they most often walk around confused.
I have the same problem with women so I now avoid them.
Old Sep 25, 2014 | 03:06 AM
lump8757's Avatar
Mechanics like me?? What are you trying to get at by saying that?
Old Sep 25, 2014 | 01:41 PM
aowRS's Avatar
I got tired of waiting for a reply.
Someone replied to your question 45 minutes later. Not 45 days later...
Andreas
Old Sep 26, 2014 | 03:16 PM
lump8757's Avatar
Originally Posted by aowRS
Someone replied to your question 45 minutes later. Not 45 days later... Andreas
sorry for being impatient??
Old Sep 27, 2014 | 12:58 AM
wyoming9's Avatar
Red face
I simply meant some mechanics work on one brand of anything throw something else at them they panic .
I work with them on a daily basis .
Then you stated I did this repair a 100 times but yet you had to ask for help then you were so inpatient till you saw it was like similar things you had done.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
