96 4runner soft brake pedal
Old Jul 14, 2014 | 05:50 AM
roland750's Avatar
I recently had a leaking rear wheel cylinder. After the brakes were replaced I've had a inconsistent brake pedal which leads me to believe that there is air in the lines. I have ABS so I've done some research and found some info for bleeding brakes for a later model Gen3 with ABS and was wondering if this procedure applies to earlier Gen3.
File Type: pdf
Old Jul 21, 2014 | 10:29 AM
Just_Me69's Avatar
Why wouldn't it? Just bleed the brakes like normal. Probably starting with the rears; where the problem started.
Old Jul 21, 2014 | 11:48 AM
JasonYota's Avatar
X2. Bleed them in the correct order though.
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
