w59 input shaft replacement ?
Old Aug 26, 2014 | 07:28 AM
trx125's Avatar
Looks like I'm going to have to replace the input shaft on the transmission. What I would like to know is with the bearing cover in removed and the case seperated, can I remove the input shaft from the main shaft without having to disassemble the entire thing. Basically can I remove the input shaft from the main shaft, install a new bearing on the new input shaft and reassemble everything? Thanks.
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
