Front Driveline Noise
Old Aug 26, 2014 | 07:53 AM
GOH10 Runner's Avatar
In my hunt for a 3rd gen I have come across two '01s that seem to have a very nasty front driveline noise. It seems like a groan/grind that happens almost as soon as you start moving, seems to change a little bit with speed, not weight/direction sensitive, doesn't change if in 4WD or 2WD. On the trucks one has axles that look perfect, one has a torn boot, one has Cooper road tires, and one is lifted with Duratracs.
Here's a video of one truck (turn volume up and ignore what sounds like change rattling):
Am I looking at actual diff issues or is this more of an axle/needle bearing issue?
Old Aug 26, 2014 | 08:30 AM
driveshafter's Avatar
ill bet the cv axel is shot pull them out and ser if that fixes sound
Old Aug 27, 2014 | 04:25 AM
aowRS's Avatar
A few months ago I chased an ever-increasing drivetrain noise that I assumed was coming from the front end (truck had just over 300k at that point with original wheel bearings, CV joints, u-joints - everything). By the time I found the actual culprit (RR wheel bearing), I had replaced both front bearings, front halfshafts, and front diff. The halfshafts and diff were 60k used pieces.
Moral of the story - drivetrain noises travel. I've now put an additional 10,000 miles on my work and all is quiet & smooth. No leaks. What an exercise...
See this thread
Andreas
terminator
Jul 27, 2015 07:13 PM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
