Belt slipping?
Old Apr 9, 2009 | 07:21 AM
MikeMc709's Avatar
Belt slipping?
In December 2008 (3 months ago aprox) I got all my belts replaced (A/C, Alternator, and Power Steering) and when I start my I hear a high pitch skretch for a second that sounds like a typical car with the belt slipping, it goes right away and never hear it again till I start my car up again. Should I be concernced?
Old Apr 9, 2009 | 07:39 AM
algranger's Avatar
Shouldnt be much of a problem if your still charging and turning the water pump etc.
Just go and retighten them they may have stretched a little bit since they are new
Old Apr 9, 2009 | 03:08 PM
MikeMc709's Avatar
Yeah averything still is working fine..it's more of an annoyance then anything
Old Apr 9, 2009 | 03:11 PM
algranger's Avatar
Yeah you could try spraying a little belt dressing on there.. your local auto parts store will have it
Old Apr 9, 2009 | 03:18 PM
Godzilla's Avatar
Try to avoid the belt dressing. That stuff turns into an ugly goo. Odds are you just need them snugged up a bit as mentioned.
Old Apr 9, 2009 | 10:00 PM
98runner210's Avatar
I think belt dressing is a horrible idea! It makes a big mess everywhere. A belt is an easy low cast item that should be replaced or adjusted. I have also seen where people use belt dressing then it turns into where they have to use it all the time otherwise the belt squeeks worse
Old Apr 10, 2009 | 03:51 AM
dsasteel's Avatar
Same thing with Chapstick! But yeah just snug them down and the squeak will stop.
Old Apr 10, 2009 | 04:38 AM
BigBallsMcFalls's Avatar
they just need to be tightened again.
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
