100k miles on 4RUNNER
Old Apr 16, 2009 | 02:21 PM
frohbego's Avatar
My 2002 4runner just hit 100k miles. any recommendations before i get my annual inspection. might as well get everything done at once.
i had the front and rear diff changed when i bought it at 65k miles.
Thanks!
-Jon
Old Apr 16, 2009 | 03:01 PM
Cbohl51's Avatar
Usually want to replace the water pump and timing belt around this time, spark plugs if you haven't changed them, check air filter, lube the U-Joints on front and rear drive shafts and give a good look over the under carriage for worn bushings etc.
Old Apr 17, 2009 | 06:51 PM
frohbego's Avatar
thanks everyone!! i'll keep my 4rruner for a long time!
this list should get me started -
trans
t-case
Diffs
Timing Belt
Water Pump
Oil / Cam Seals
Plugs
how much are we talking to get these done at my local show. Just wanted to get an estimate so i set aside some cash.
-JON
Old Apr 17, 2009 | 08:27 PM
jmoore9982's Avatar
Now that it's broken in you don't need to baby it as much.
Old Apr 18, 2009 | 05:55 AM
Cbohl51's Avatar
I haven't taken a vehicle in for any work in 8-9 years, but I would say that around 600-800 for all the work is a good estimate. If you are somewhat handy, you should be able to change your plugs, air filter, and change out the fluids. That way, you will only need to have them take care of the timing belt and water pump, and save yourself some money.
Old Apr 18, 2009 | 06:59 AM
DinoEck's Avatar
Honestly, beyond plugs, plug wires and filters, I'd leave it alone. I think they end up screwing up stuff more often than fixing it.
My '98 has 132k and still going strong.
Old Apr 18, 2009 | 02:02 PM
eddieleephd's Avatar
Talking
x2
x2
x2 after TB water pump and dont forget the front oil seal while they have it open!
you may want to seafoam it soon for good measure, of course before the new plugs!
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
