rear brake bulb replacement
Old Dec 20, 2006 | 08:14 PM
Ladythump's Avatar
My two tail brake lights are out on my 1999 Runner Limited V6. The third light on the tailgate is working fine. I'm thinking both bulbs are burnt; weird they'd go around the same time. Never the less, how do I access the bulbs and what is the replacement part?? I've done a search and found nothing.
Thanks.
Old Dec 20, 2006 | 08:17 PM
Elton's Avatar
https://www.yotatech.com/forums/showthread.php?t=76367......also check the fuses
Old Dec 21, 2006 | 07:12 AM
eric-the-red's Avatar
Originally Posted by Elton
If the 3rd brake light is working no need to check the fuse. And Ladythump it's very probable that both bulbs went at almost the same time. It seems to be common on Toyotas that if one bulb burns out the same one on the other side goes very soon after.
Old Dec 30, 2006 | 08:44 PM
Ladythump's Avatar
Thanks guys. I'll get those changed right away.
Old Dec 30, 2006 | 09:16 PM
DeathCougar's Avatar
2 10mm bolts holding the housing on, then 2 clips there after (should be able to pop it out by hitting it with the but of your hand) Not 100% sure what the bulb number is then, but I am finding them online with the part #7443
Old Dec 30, 2006 | 09:17 PM
or you can use a philips screwdriver.
Doh. I read that writeup after I posted.
gillesdetrail
Nov 19, 2019 12:56 PM
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
miceal383
Jun 29, 2015 12:27 AM
cchinny
Jun 25, 2015 08:11 PM
