rear brake bulb replacement
My two tail brake lights are out on my 1999 Runner Limited V6. The third light on the tailgate is working fine. I'm thinking both bulbs are burnt; weird they'd go around the same time. Never the less, how do I access the bulbs and what is the replacement part?? I've done a search and found nothing.
Thanks. :bowdown: |
https://www.yotatech.com/forums/showthread.php?t=76367......also check the fuses
Originally Posted by Elton
(Post 50368558)
Thanks guys. I'll get those changed right away.
2 10mm bolts holding the housing on, then 2 clips there after (should be able to pop it out by hitting it with the but of your hand) Not 100% sure what the bulb number is then, but I am finding them online with the part #7443
or you can use a philips screwdriver.
Doh. I read that writeup after I posted. |
