Need help replacing my Radiator.
Old Dec 22, 2006 | 10:31 AM
Myron's Avatar
Hey guys, i have a 98 tocoma, I need to replace my radiator. Do i have to take of my front bumber or can it just come out like that. If some one has a quick run down or how to guide. i will appreciate that.
Thanks
Old Dec 22, 2006 | 10:33 AM
Elton's Avatar
need to drain it first and then remove the fan shourd and there should be 4 bolts holding it on
Old Dec 22, 2006 | 01:56 PM
mt_goat's Avatar
The bumper shouldn't be in the way at all. X2 what Elton said, plus the coolant hoses of course, and if it's an auto the ATF coolant lines need to be disconnected.
Old Dec 22, 2006 | 01:59 PM
Myron's Avatar
thanks for the info....Any one has pics...or a step by step processs...
thanks
Old Dec 22, 2006 | 02:15 PM
mt_goat's Avatar
Should be the same for your's as this 2003 FSM shows: http://www.deserted1.com/FSM/
Do you have a V6?
http://www.deserted1.com/FSM/Repair_.../radi/remo.pdf
For some reason they reference BO-8, maybe you need to remove the grill?
http://www.deserted1.com/FSM/Repair_.../head/remo.pdf
Old Dec 22, 2006 | 03:17 PM
Myron's Avatar
Its a 3.7 v6 ...thanks for the help
Old Dec 23, 2006 | 07:31 AM
4Crawler's Avatar
The bolts holding the radiator on are behind the grill. Not sure if the must come off but it would make it easier to get to those bolts:
http://www.4crawler.com/4x4/ForSale/...oyotaRadiators
Old Dec 23, 2006 | 07:41 AM
jjrgr21's Avatar
i did mine on my 98, the grills gotta come off, un hook the hoses, get a new thermostat while your at it, drain it, leave the fan shroud hang on the fan and the four bolts and thats it, easy one man job
Old Dec 24, 2006 | 08:04 AM
Tanto's Avatar
Originally Posted by Myron
Its a 3.4 v6 ...thanks for the help
Fixed it for you.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jjrbus
Jul 17, 2015 07:06 AM
1994toyota
Jul 17, 2015 03:03 AM
Avenged
Jul 9, 2015 07:55 AM
