Help with bouncy/wobbly 96' Runner ride!
Old Jul 29, 2009 | 10:04 AM
apache67's Avatar
Howdy Folks,
I recently picked up a well used 2WD 1996 4Runner. At lower speeds the ride is ok. However, at higher speeds I can feel a vehicle shimmy, as well as, steering wheel shimmy. I suspect that this vehicle has the original shocks and springs and I think that I would like so start with replacing them.
Can someone please recommend good replacement OEM springs and shocks and a location to buy said stuff? I'm driving this car on Houston city streets (which suck) and I just want a decent factory-like ride I guess.
Phase two: Is to get some tire replacements for the tires that are undoubtly one of the culprits in my shimmying wobbly ride. There is a place in Houston that refurbishes the classic brushed aluminum wheels for 4runners (I have the steel rims). Can you guys please recommend a set of tires to go on these rims?
Phase three: Can someone identify additional causes for the crummy ride of the vehicle? Some things that I can replace that I'm sure need to be replaced that are just worn out after 165,000 miles that's on this vehicle?
Thanks Very Very Much for any and all suggestions!!!
G
Old Jul 29, 2009 | 11:14 AM
apache67's Avatar
Thanks for the suggestion Buhundred. I'm not really wanting a system that lifts the vehicle by 2". Do you any other suggestions/sources for OEM?
Thanks Again,
G
Old Jul 29, 2009 | 11:23 AM
Lumpy's Avatar
I'd just start with at least getting the tires balanced. If they are worn the replace them. I'm sure that this will fix most of your issues.
Old Jul 29, 2009 | 11:25 AM
apache67's Avatar
I already balanced and rotated the tires. Plus, I did an all wheel alignment. I think the tires are shot because the shocks and springs are likely worn out. They look like the original coils and shocks to me.
Thanks!
G
Old Jul 29, 2009 | 11:36 AM
scuba's Avatar
Originally Posted by Buhundred
which increased BODY ground clearance.
Did nothing for the axle ground clearance
Old Jul 29, 2009 | 11:37 AM
apache67's Avatar
Not sure. I don't have the vernacular. Can you please take the time to explain this adaptor?
Thanks Again, I appreciate the fast responses.
G
Old Jul 29, 2009 | 11:54 AM
apache67's Avatar
Wow! Good article. Thanks much! These shocks and springs you recommended; are there any other suggestions that are little less expensive?
G
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
