Old Mar 30, 2016, 02:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Engine Guides
Print Wikipost
Check Engine light come on after oil change never done it before. help
Old Nov 24, 2005 | 02:01 PM
toyota884runner's Avatar
Check Engine light come on after oil change never done it before. it came on right after i drove up a hill and stays on. the dipstick says it is fine oil wise. what could it be?? it's a 88 4 cylinder 22re 4runner. please reply
Old Nov 24, 2005 | 02:03 PM
Tacoma Dude's Avatar
Coincidence?
Check engine light or the oil light?
Old Nov 24, 2005 | 02:04 PM
check engine
Old Nov 24, 2005 | 02:08 PM
bamachem's Avatar
knock a vacuum line loose when you refilled or changed the filter?
Old Nov 24, 2005 | 02:10 PM
Best to diagnose the CEL then. It could be entirely unrelated or it could be something that you inadvertantly messed up while changing the oil.
You can't do this in CA but I hear that in most other states you can go to a local Kragen's or Pep Boys or something and they can find out what the trouble code is. That will be your best start.
OR if you happen to like tools and plan on doing a lot of your own work you can get a diagnostic tool for around $200 or a code reader for $50 (rough estimate of prices)
Old Nov 24, 2005 | 02:44 PM
i pout a toyota filter on it before i had used fram. could it be the filter. box says 22-r but not 22-re
Old Nov 24, 2005 | 02:51 PM
wimpywade94's Avatar
Check your knock sensor, they happen to get knocked loose pretty easy, located right next to the filter, little bit above it and towards the firewall a little more,
i guarntee thats the problem.
wade
Old Nov 24, 2005 | 02:52 PM
NathanBERG's Avatar
Have you checked the code?
Old Nov 24, 2005 | 03:06 PM
it is the plug that goes it to the block right next to the filter?? i have wire that has been pulled out does it go into that plug????
Old Nov 24, 2005 | 03:20 PM
NathanBERG's Avatar
If looking at the oil filter thru the pass front wheel well, directly south of the oil filter is the Oil pressure sensor, south/west of the oil filter is the knock sensor location.
http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Nov 24, 2005 | 03:41 PM
thanks guys for all your help!! problem solved. you were right wade.
Old Nov 24, 2005 | 08:34 PM
What do i win?!!??
j/k glad i could help
wade
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
