Symptom of a bad starter?
Old Dec 5, 2005 | 11:22 AM
bryanr's Avatar
As the frigidly cold weather has begun to set in, my truck has encountered a few recent starting issues.
The past 2 weeks or so, when I first go out in the morning and turn the key, it clicks and I can hear what I assume is the starter spin, but it doesn't try to turn the engine over. After 4-5 attempts it catches and the truck starts up. However, it won't have this issue until the next morning. When I drive to work and leave for lunch 5 hours later, it never acts up. Or when I leave to go home for the night it never acts up. It only seems to happen sitting over night in the extreme cold. I thought a starter problem would be more consistent, not just during cold weather, so I might be off thinking that's the cause of the problem.
Any ideas?
Old Dec 5, 2005 | 11:32 AM
4Crawler's Avatar
See page below for troubleshooting and repair info:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old Dec 5, 2005 | 03:33 PM
tc's Avatar
tc
Wow - this is the second time I've posted this link tonight...
https://www.yotatech.com/forums/show...battery+heater
Does the starter sound normal or slower? Batteries lose A LOT of their power in the cold. Actually using them will get them heated up a bit and able to supply enough power to get the truck going. Then you have enough heat in the engine bay to get full power.
Some other things - check/upgrade your ground wires and have your battery checked at AutoZone, Advance, etc - it may be on its last legs. If replacement is due, I would recommend getting more cold cranking amps
SubiKing
Aug 21, 2021 03:57 AM
crammit442
7
Nov 29, 2017 12:30 PM
129Creepin
Aug 5, 2015 10:12 PM
clok
Aug 1, 2015 09:42 PM
colinmil
Jul 6, 2015 04:03 PM
