Engine Stalls when warm
Old Aug 16, 2012 | 08:01 AM
randomco's Avatar
Hey Guys,
I'm a newbie here but found this site to be really informative!
I am having a problem with my 2002 Toyota Tacoma 2.4L automatic. When the truck is first started in the morning, it runs fine until the engine temp reaches a normal level, then the truck stalls. I can tell it stalls because the speedometer drops to 0. The truck then starts right back up automatically and the speedo goes back up to current speed, sometimes the speedo bounces up and down. It also tends to stall at stop lights. The truck always fires back up, but sputters when accelerating for a bit, then smoothes out.
I first cleaned the IAC valve with carb cleaner, same problem.
I then replaced the Idle Air Control valve for a new one, put in a new Throttle Position sensor, changed the fuel filter.
I thought this fixed my problem as the truck started right up and ran good for about 5 minutes. Then as soon as the truck got warm again, it stalled at a stop light. It then sputtered and continued to stall until I could make it home.
No check engine light on
Any ideas??
2002 Toyota Tacoma 2.4L, automatic, 180,000 miles
Old Aug 16, 2012 | 08:52 AM
tantacoma's Avatar
The issue could be with your IAC or the MAF sensor.
Might need replacing or just a good cleaning. Lots of posts about this stuff.
Do a search for more information.
Old Aug 16, 2012 | 08:55 AM
randomco's Avatar
I've already changed the IAC valve for a new one. The MAF sensor looks brand new when I remove it.
I've searched the forums but cannot find anything that describes my issue exactly. Most are about hard starting at warm temp, the truck has no problems starting, even after the truck stalls
Old Aug 16, 2012 | 09:43 AM
Dirt Driver's Avatar
Codes?
Shouldn't the speedometer keep reporting as long as the key is on RUN, regardless of the engine running or not? I'm thinking yes, which makes me think that you might have an intermittent electrical fault. A code scanner can be used to monitor the ECU when the problem occurs.
Old Aug 16, 2012 | 09:57 AM
randomco's Avatar
you would think that the speedo should remain accurate even when the car stalls, but it drops to zero.\
I have heard that it may be the VSS (vehicle speed sensor) that is causing this to occur. Anyone have experience with this sensor?
Old Aug 16, 2012 | 10:12 AM
Another reason to check for any codes. Your driveline combination should trip a P0500 if the VSS is causing a problem.
Old Aug 16, 2012 | 10:16 AM
randomco's Avatar
there isnt a check engine light on. I will check the codes tonight anyway, thanks.
Old Aug 16, 2012 | 02:52 PM
randomco's Avatar
So after I used the code reader, I got a p0340, camshaft position sensor error. I shut the truck off and looked under the hood for this sensor, could not find it. I went back into the truck and checked the code again and it said no errors, wtf?˟
Where is the camshaft sensor located?
Old Aug 16, 2012 | 07:41 PM
enapa's Avatar
Behind timing cover on the 3.4 dont know about yours.
Old Aug 16, 2012 | 07:51 PM
rworegon's Avatar
Does post 9 below help?
https://www.yotatech.com/forums/f2/r...-whats-213177/
or:
http://www.tacomaworld.com/forum/1st...on-sensor.html
Old Aug 17, 2012 | 08:07 AM
That is why checking for both KOEO and KEOR codes should be the first step in troubleshooting a problem like this. No CEL ≠ no codes.
There are service manuals available free online if you look around...
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Jonny246
Jul 12, 2015 04:51 AM
Kluch8651
Jul 9, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
