Read End Noise
Old Aug 20, 2012 | 08:56 AM
mcdmusic's Avatar
Question Read End Noise
I have a 2000 4runner with 186k miles that has started a rear end noise, no change when turning or engine off, loudest about 50mph+. Tires are old and will be replaced in the next few months, but this noise doesn't appear to be tires. First fix i have tried was changing the diff fluid, and greased the U-Joints. I recorded the sound using my phone sitting above the rear axle. The youtube video has two segments one is driving between 50-60mph and the next has a deceleration to zero.
Any ideas on the next step to diagnose?
http://www.youtube.com/watch?v=BVPu4...ature=youtu.be
Old Aug 20, 2012 | 06:28 PM
James Woods's Avatar
So how have you eliminated the tires? Or the U joints? I would put the rear on jack stands and listen to it with a stethoscope or screw driver. I don't have sound on my puter so I can't listen to your video.
Old Aug 21, 2012 | 08:52 AM
mcdmusic's Avatar
Already greased the U-Joints, going to put the rear on jack stands this weekend. Currently its hard to hear the "other noise" over the tire noise.
Old Aug 21, 2012 | 11:06 AM
Qyota's Avatar
Sounds very similar to my '00 limited. Probably differential bearings. Mine hasn't gotten worse in over a year, so I'm just leaving it for now...but I know when the time comes it will need to be replaced. I'm thinking ECGS rebuilt third.
Old Sep 4, 2012 | 08:16 AM
mcdmusic's Avatar
Got it on a lift last week, definitely the rear diff and loudest at the pinion bearing. We used a stethoscope to listen with it in drive on the lift. Since finding an elocker in a junkyard is going to be near impossible next up is East Coast Gear supply for a rebuilt diff. http://eastcoastgearsupply.com/i-131...ocker-3rd.html
Anyone measured the axle length so i know how much room i need in the garage to pull the axles? I don't want to get it torn apart to find i don't have enough space.
Old Sep 4, 2012 | 11:51 AM
mastacox's Avatar
I think you're going to need about 3.5 feet on each side to be able to pull the shafts.
Old Sep 28, 2012 | 10:17 AM
mcdmusic's Avatar
Smile
Just to follow-up on the outcome, I installed a rebuilt from ECGS last weekend, everything worked great. The new one is silent, thanks to Zuk for recommending them. Once i took the driveshaft down i could feel the play in the old 3rd when turning back and forth, guessing that was backlash.
Now its time to
Old Sep 28, 2012 | 01:04 PM
Qyota's Avatar
Thank you for the follow up. This pretty much confirms this is what's wrong with my truck. Good to know there is a fix, at least. Not sure my skills are up to a 3rd member swap, but we'll see!
Old Sep 29, 2012 | 01:33 PM
Qyota's Avatar
Any tips for the swap? Pitfalls? Gotchas? :-)
Yota.Jay
Jul 23, 2015 08:08 PM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
