Gas fumes inside 2000 4runner
Old Aug 13, 2012 | 01:15 AM
Browntown3's Avatar
Guys, ive been noticing especially after fillups a greater than normal existance of gas fumes inside the cab of my 4runner, i know some can get in on fueling up etc. but this is way too much happens every fill up, but also i can smell fumes really any time i walk around the truck faintly. Never had this happen with any other vehicle ive had, i was wondering if there was some kind of vent on the tank that had a hose or something that might be broken allowing fumes to enter the cabin? Or, i noticed mine has what seems to be an aftermarket gas cap that says "Vaccum Only" which leaves me to believe its not a venting cap? Could that be the problem ?
Old Aug 13, 2012 | 05:15 AM
waskillywabbit's Avatar
Have you looked for leaks in the filler neck or vent hose?
Cheap gas cap would do it too.
:wabbit2:
Old Aug 13, 2012 | 05:37 AM
Browntown3's Avatar
I checked aroudn the filler neck and hose following it to the tank and everything looks dry, do you know where the vent hose is located ?
Old Oct 22, 2012 | 10:00 AM
NickB47's Avatar
I've got the same issue at the moment. Do a search for "fuel smell" or "gas smell" and you'll turn up a few things under the hood like the charcoal canister or the fuel pulsation damper.
https://www.yotatech.com/forums/f116...-front-246122/
I just picked up my rig and have yet to find the source of the smell/leak but you should NOT be driving if you can smell fuel. If/when it ignites you can imagine the consequences... not work the risk.
mskalmus
May 28, 2017 07:51 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
