Not moving when letting off the brake?
Old Aug 10, 2012 | 05:38 AM
Sublime69's Avatar
This might be a stupid question but I just bought an 02 4runner with 116K miles. When I first start driving the car and let off the brake from a stop the car doesn't creep forward. After it warms up then it will move forward when letting off the brake. Is this normal? Every automatic car i have owned has moved forward hot and cold.
The car drives perfect tho, trans shifts great and fluid looks good too.
Thanks
Old Aug 10, 2012 | 07:18 AM
DRCOFFEE's Avatar
sounds like the brakes aren't releasing. It should be looked at.
Old Aug 10, 2012 | 02:08 PM
Sublime69's Avatar
Brakes seem ok.. the pedal is low but they are releasing
Old Aug 11, 2012 | 02:51 PM
kball's Avatar
Leaking rear axle seals are known to bind the rear brakes up when cold. Not sure how cold you're talking about but if the back of your rear tire/brake hub is wet then there you go...
Flying91
45
Apr 11, 2024 04:39 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
coryc85
Sep 9, 2015 06:24 AM
Johntom240
7
Jul 13, 2015 12:18 AM
