Oil pressure sending unit
Old Jul 4, 2012 | 11:45 AM
Simon's Avatar
Exclamation Oil pressure sending unit
Hi guys, its been a while since I posted as my 4Runner has been running great. So today I changed the oil and as I was taking off the oil filter, the wrench slipped and busted off a screw on piece right next to the oil filter. It has a spring in it and looks like a sensor of some sort. The truck runs fine and I will get it replaced ASAP, but I was wondering if anyone knew what the sensor actually does and if its ok to drive the truck in the mean time before I bring it to the dealer. Here some pics.
As always, thank you to all the great people and info on this site!! Oh yeah, Happy 4th of July!!!
Old Jul 4, 2012 | 11:30 PM
anthony1's Avatar
That looks like an oil pressure switch.....not a sender.
It's the kind that goes to the light not a gauge.
Old Jul 5, 2012 | 01:51 AM
Terrys87's Avatar
I would replace it as soon as possible. It is under alot of oil pressure and if it pops a leak, it will spew oil out fast.
I was swapping one from the light to the guage and the head of the unit busted off leaving a hole right threw the center of the threads. Take your time getting it off. Make sure you get a good fit with the wrench.
Old Jul 5, 2012 | 05:17 AM
Texas_Ace's Avatar
Are you getting any lights on the dash? I would pick up another switch, a place like pepboys should have the right part for cheap.
Old Jul 5, 2012 | 06:07 AM
Simon's Avatar
Thanks guys for the replies. No lights on the dash. Most of the piece is still screwed in so I don't think there is a chance oil will come out, but I hadn't thought of that possibility before.
Mr. Ace, you think an autoparts store would stock it? I thought it may be something I could only pick up at the dealer, but I'll check around at some of the autoparts stores first. Thanks again!
Old Jul 5, 2012 | 06:08 AM
Texas_Ace's Avatar
Yep, an oil pressure switch is a pretty common part. They should have one. I picked one up for my MR2 for $18 IIRC.
Old Jul 7, 2012 | 01:21 PM
pattycakes77's Avatar
I don't know if it's the same thing but...
https://www.yotatech.com/forums/f2/o...-5vzfe-247947/
Maybe it will help you out, maybe not. The plastic on mine was cracked a little and spewed oil like crazy!
Old Jul 20, 2012 | 08:27 AM
Simon's Avatar
Yep, that is the same part. Mine wasn't leaking though since most of the sensor was still screwed in. I got the 12.99 one from Advance Auto and it installed and is working. I assume. Since I can't tell a difference with it plugged in or not. Thanks guys!!
Old Jun 16, 2014 | 12:13 PM
PW4Runner's Avatar
Hi,
I see that this post is already a couple years old, but can someone tell me what the Toyota part number is for this oil pressure switch? I have a 2000 4Runner 3.4L. My switch has been leaking since my last oil change so I need to replace it but need the part number.
Thanks very much!!
Old Jun 16, 2014 | 04:27 PM
rworegon's Avatar
Looks like possibly 83530-0E010 from here and here.
Old Jun 18, 2014 | 02:54 PM
PW4Runner's Avatar
Thank you very much!!
Doug4320
Mar 24, 2018 10:11 PM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
