ABS speed sensor
Old Oct 17, 2005 | 10:26 AM
Elvota's Avatar
Question ABS speed sensor
Was wondering if anyone knows what the ABS sensor on top of the rear diff picks up on? What does it use to track the speeds gears and such are moving? If one puts in aftermarket gears, does the sensor loose its ability to know what is going on back there?
I guess I am wondering whether there is something in the factory gear that the sensor reads.
Thanks
Old Oct 17, 2005 | 10:42 AM
MTL_4runner's Avatar
Thanks
What vehicle is this regarding?
ABS sensors read a magnetic ring which can be located almost anywhere on the drivetrain (most often located at each wheel).
Can't say much more without knowing what vehicle.
Old Oct 17, 2005 | 11:49 AM
Flamedx4's Avatar
Seems to read the teeth on the ring gear. If you remove it and look inside, you see the teeth. Changing the number of teeth shouldn't matter, but some have reported a problem with it reading after a gear change. Tolerance might be the issue = distance from the ring gear. Normally they have to be very very close.
Old Oct 17, 2005 | 11:50 AM
eric-the-red's Avatar
2nd gens with rear anti-lock have 1 sensor on the rear diff. Looking at the manual it doesn't show anything on the differential. Looks like the sensor just determines if the ring gear is rotating or stopped.
Old Oct 17, 2005 | 11:56 AM
snap-on's Avatar
I thought the ring gears of ABS equiped trucks (of that age) had an ABS ring affixed next to the ring gear. looks like a saw blade with sq teeth. the sensor reads these sq teeth as opposed to the actuall teeth of the ring gear.
Old Oct 17, 2005 | 12:59 PM
Flamedx4's Avatar
With 4 wheel abs I would say that's probably always gonna be true. The controller needs to know if the fronts and rears are turning at different speeds (also needed for &*%$# traction control ) but for rear wheel abs turning/not turning is all it really needs to determine. I can tell you for certain that there was no tone ring inside my diff when I removed and regeared and reinstalled it.
Aha! In the FSM for rear wheel abs it says "inspect the ring gear (sensor rotor) for scratches, cracks, warping or missing teeth. If necessary, replace the ring gear." And shows the sensor at the teeth edges.
And in the function test for the sensor, all it's looking for is a signal. It's a signal/no signal function test. So it doesn't care what ring gear is in there, as long as the mag pickup can read off the serrations.
Old Aug 9, 2010 | 06:51 AM
kurtdaniel's Avatar
ive read that this ABS Speed Sensor system provides individual control of the front wheels, so they can both achieve maximum braking force.
krimsonone
Sep 13, 2024 09:33 AM
montanatruck
Feb 26, 2017 07:07 AM
ty1er
Aug 1, 2015 11:53 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
