84-87 horn & dome light problems
Old May 29, 2004 | 07:46 AM
barkeywayne's Avatar
I have/have had several of the 84-87 2wd and 4wd pickups and it seems like almost every one of them has had intermittent or non-working horns and the dome light (particular when drivers door is open) didn't work. I haven't tried to fix any of mine lately but it seems like when I have tried to fix these things by checking the obvious stuff like fuses/bulbs/switches I never could figure them out. Anybody have any experience on what causes these problems?
Old May 29, 2004 | 08:07 AM
toy283's Avatar
In the case of the horn, in all likelyhood, the wiper isn't contacting the contact ring inside the steering wheel. This is usually the case after the truck is ten years old or so. There are two possible solutions to this:
1. remove the steering wheel and shim up the contact ring mounted to the back of it with a few small washers (one washer per attachment point (3)). Cheap and easy but only works once. After that you must:
2. Remove the steering wheel and replace the contact (Toyota p/n: 84312-20011 for my '84 & '85) in the steering column. A little more expensive but still easy.
The dome light still has me baffled as well. Mine are driving me crazy
Old May 29, 2004 | 09:09 AM
I will try the shim trick on the horn, that's a good idea, thanks. I thought it must be somewhere from the steering column up, I had pretty well checked everything else.
Maybe somebody else will step up with a dome light fix.
Old May 29, 2004 | 03:42 PM
tallboy's Avatar
Does your ears ring when the door is open?
Does your door buzzer work? If not then somebody has removed the buzzer relay pack. That works in conjuction with the dome lite. I removed the buzzer and then a couple of days later I noticed my dome lite did not work when the drivers door was open. The door buzzer is located under the dash up around the steering coulm. It also could be that it has gone bad. You can jumper the termial connection to do away with the buzzer. I will have to look at mine to remember what two termials to do. Let me know if this is the case with yours.
Greg
Old May 29, 2004 | 04:04 PM
cabbage's Avatar
Unhappy
So Im not alone!! Horn doesnt work, I took it apart last year and found out that the contacts werent touching...but, never got to it and I rarely need to use it.
About the light... mine worked fine till I went through some deep mud/water early this year, it would work once a while but then if I wash the truck or it rains it doesnt work again... I believe its the door switch, but I took them apart and cleaned them real good, still doesnt work
Old May 29, 2004 | 04:06 PM
cabbage's Avatar
Greg
Hey tallboy, do you have any pics of where the buzzer is, I had my truck for awhile now, never had a buzzer(even when the light was working).
Thanks!
Old May 29, 2004 | 04:13 PM
FSRBIKER's Avatar
What about if your horn sounds REALLY low but works?
Old May 29, 2004 | 05:24 PM
Greg
I will definitely check that out, I don't think the door buzzer works on any of my 84-87s. I bought all of them with well over 100K, wouldn't be surprised if someone had unhooked the buzzer on all of them. I'm guessing there is 2 wires to the buzzer and you can just hook them together? If you get a chance give yours a look and let me know sometime, thanks!
Old May 29, 2004 | 05:41 PM
tallboy's Avatar
How I got rid of the buzzer.
I used a 3" wire with two male spade connectors and jumped that curcit in the OEM plug. At least that way there is no hacking of the factory harness.I hate the buzzer, it drives me crazy. When you find the plug with the square end pointing down to the floor it should be the two on the top left of the factory plug. The square end is the oposite of the lock tab on the factory plug. At least that worked on my '87.
Greg
Old May 29, 2004 | 05:56 PM
tallboy's Avatar
Nope
Thanks!
Sorry no pictures I don't have a digital camera as of now. But I can tell you that the buzzer is on the right of the steering colum above the gas and brake pedels just left of the parking brake handle. I also posted what I jumped on the OEM plug after the buzzer was removed to correct the drives door dome light problem.
Greg
Old Apr 11, 2011 | 06:11 PM
worshipmentor's Avatar
Can verify that this works on my 87 as well. The buzzer was almost as annoying as a liberal at a TEA party meeting! bypassed it and light works as it should. my issue is that I HATE the stock dome light/mirror combo (plus my lens is gone) and want to replace it with something...... any thoughts????
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 11, 2015 08:08 PM
madxman21
Jul 9, 2015 10:26 AM
