How to replace control arm bushings?
Old May 28, 2004 | 01:27 PM
az4x4runner's Avatar
Question How to replace control arm bushings?
What do you have to do to replace the lower control arm's bushings? I assume I have to remove the whole arm... is this a job I dare attempt on my own?
Thanks...
Old May 28, 2004 | 02:41 PM
mt_goat's Avatar
Thanks...
Yes, you have to remove the arm. You will also need a press or at least a huge vise with a long cheater bar on the handle. The new bushings go in a lot easyer than the old ones come out, or they did for me anyway.
Old May 28, 2004 | 05:51 PM
86toyota's Avatar
Mt goat is correct. One other thing thou, sometimes the adjusting bolt seizes in the bushing sleeve. Then you'll have to torch them out and replace the special bolt and nuts.
Old May 28, 2004 | 10:01 PM
Mossback74's Avatar
And get an alignment afterwords
Old May 29, 2004 | 04:49 AM
mt_goat's Avatar
Speaking of alignment, mark where your adjustment cams are before you loosen the bolts. That will help you get it back close to alignment, at least until you can get to the shop.
Old May 30, 2004 | 01:10 AM
Thank you for the info/tips guys.
It may be a while before I can get around to replacing them though, it wont damage anything for me to drive/wheel in the current condition will it? The bushings are still there (I've inspected them), just not in the greatest condition I guess.
Unless something else is causing my occasional front end rattle/clunk noise on rocks/ruts and slightly off alignment (even after having it re-aligned).
Old May 30, 2004 | 03:37 AM
Mossback74's Avatar
Shocks/shock bushings, or swaybay bushings
Old May 30, 2004 | 11:07 AM
I dont think it's the shocks, and I don't have front swaybars
I'm just kind of curious if it'll damage anything to go 4-wheeling with the bushing worn like that, since I have a somewhat long drive planned tomorrow across some interesting terrain.
Old May 30, 2004 | 10:16 PM
I'm just kind of curious if it'll damage anything to go 4-wheeling with the bushing worn...
So I take it noone is sure if it'll damage my control arm or whatever?
Old May 31, 2004 | 04:58 AM
mt_goat's Avatar
I can't think of a way it would hurt your control arm, unless the bushings came out and I can't see that happening. I think worn LCA bushings should only cause slop in the LCA. I think the worst thing about that would be quickly wearing your tires out and bad handling. But hey, I'm no expert on it.
Old May 31, 2004 | 06:50 AM
Ok, I didn't thinnk it would damage the LCA, I just wanted someone elses opinion on it as well, thanks.
Old May 31, 2004 | 01:33 PM
ChickenLover's Avatar
Silver954runner,
Good luck, and let me know how it goes. I'm planning on doing mine in a couple weeks. That rattling is enough to drive me nuts.
Old May 31, 2004 | 02:10 PM
Yeah! It drove me nuts today, I just got back from about a 4 hour trip out past Palace Station and down Bodie Mine Rd. It was annoying as hell, I usualy don't like having my music turned up when I'm 4-wheeling so I can hear if anything breaks, but this time I had it up for a while just so I didn't hear the rattle all the time! lol
...at least I got some cool pictures out of it all, hopefully...
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
andrewtexas123
Jul 14, 2015 04:29 AM
cyclist231
Jul 7, 2015 12:56 PM
ptb12
Jul 5, 2015 01:49 PM
