ISR mod Question...3. slow
Old Jul 17, 2004 | 05:58 PM
Marc P's Avatar
I am in the process of doing the ISR mod. I have a turbo tube from a ford 6.0 diesel that I have cut for a perfect fit. I have seen the write up that Blu made for the mod, but I dont see one of the hoses that my truck has going to the silencer.
I have the hose coming off the valve cover, then I have 2 hoses-1 small-1 bigger hose coming from under the intake manifold. I need some pics of how you guys with the 3. slow routed these lines.
Old Jul 17, 2004 | 06:10 PM
Corey's Avatar
Co-Founder/Administrator
Marc, Blu no longer is around, I do not know what happened to him.
I have tried contacting him several times, so I assume he is no longer around.
Check with Joey who also has done the mod.
I'm sure he could get you some pics.
Old Jul 17, 2004 | 06:22 PM
AgRunner06's Avatar
Just turn the intake hose that comes off your TB sideways and then make a piece of pipe that goes from there to the AFM. Then all you have to do is extend the breather hose that comes from the driver's-side valve cover. You should have a hose that comes from the PCV valve. Just run that hose into the new piece of pipe. Here is a pic of mine. However I used PVC but you get the idea.
I reused the old hose from the valve cover because I couldn't find an 1/2" fuel line - that's what you'll need to replace it. Here's what I did to my airbox for anyone who cares.
Old Jul 17, 2004 | 06:45 PM
Marc P's Avatar
Agrunner--so it looks like you just attached the smaller of the 2 hoses to the intake tube and the thicker hose stayed in part of the silencer, is that right??
Old Jul 17, 2004 | 07:07 PM
AgRunner06's Avatar
Yep, that's right. I looked at pics of the K&N cold air kit when I designed mine. I've been running it since last fall without any problems.
:bounce2:
Old Jul 17, 2004 | 07:14 PM
Marc P's Avatar
Thanks, you answered my question. I will post pics of my custom aluminum intake when it is finished.
Old Jul 19, 2004 | 02:46 PM
UKMyers's Avatar
Do a search for my SN and the ISR mod I've posted the pics 3 or 4 times for other threads.
Old Jul 19, 2004 | 07:15 PM
Marc P's Avatar
UK--I did a search and found lots of great pics of different intakes, but none of them showed the hose I was questioning. I now have all the pieces I need, wait until you guys see this one
Old Jul 19, 2004 | 07:17 PM
UKMyers's Avatar
Cool deal let me know if you have any other questions. I think you'll be pleased with the results and the new sounds.
Old Jul 20, 2004 | 05:54 PM
Bumpin' Yota's Avatar
Corey, wasn't Blu in the military? If so, I hope the bro is ok...
Old Jul 20, 2004 | 06:28 PM
Corey's Avatar
I can't remember if he was or not, but it's been a very long time since we have heard from him.
TheBFA
Feb 15, 2020 06:55 AM
shredder4286
Oct 1, 2015 01:09 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
