Loss of power
Old Jul 12, 2004 | 07:08 PM
Praufet's Avatar
Loss of power
So I've had my new junkyard engine in for a couple of weeks and now all of the sudden I have no power. I have to be a full throttle to maintain 70 in 5th on the highway (@3000rpm). What should I check? It idles fine just no power.
Old Jul 12, 2004 | 07:15 PM
ChickenLover's Avatar
Is there any choking or studdering?
Old Jul 12, 2004 | 07:38 PM
gwhayduke's Avatar
Did you replace the timing belt?
Old Jul 13, 2004 | 05:33 AM
Praufet's Avatar
Yes I replaced the timing belt. Or rather my mechanic did, and we reset the timing to the specs given.
No stuttering its just no pull when I press down on the throttle. From idle it takes forever to get up to any speed at all.
Old Jul 13, 2004 | 06:34 AM
Praufet's Avatar
Actually after driving to work there is some stuttering if I let of the throttle just right
Old Jul 13, 2004 | 03:13 PM
Praufet's Avatar
After driving home from work I noticed a lot more stuttering, guess its just one of those things it takes some to mention to notice.
Old Jul 13, 2004 | 03:19 PM
Check plug wires, clean air filter. Could be bad gas too (though that's unlikely).
Old Jul 13, 2004 | 04:12 PM
Praufet's Avatar
plug wires are good, air filter is only 2,000 miles old. All was fine up until about a week ago.
Old Jul 13, 2004 | 04:15 PM
Should have clarified, I mean make sure the plug wires are securely connected at both ends. A loose wire will cause power loss and rough running.
Also make sure you don't have a loose vacuum line in there somewhere, that'd do it.
Old Jul 14, 2004 | 06:38 AM
Praufet's Avatar
So check plug wires and hoses all are good. Just to test something on teh freeway to work today I put it into cruise and it wouldn't hold speed. It just slowly dropped, any idea what this means? Bad tps? Something else?
Old Jul 14, 2004 | 06:44 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Sounds like bad vacuum, that's what holds the cruise control on speed.
Old Jul 14, 2004 | 06:50 AM
Praufet's Avatar
I figured it be something else since I'm having problems accelerating to begin with. Figured what ever is keeping me slow is hurting the cruise control, but I'll check that out.
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nate2919
Aug 6, 2015 04:00 AM
gmonnie123
Jul 26, 2015 02:44 PM
