2" body lift question
Old Jul 12, 2004 | 11:11 AM
904wdPickup's Avatar
I am going to add a 2" body lift to my 4" superlift and want to know if any one here has done this to there truck? And is there any complications I am going to run into on the install because I have the 4" superlift?
Thanks
TJ
Old Jul 12, 2004 | 11:20 AM
UKMyers's Avatar
Shouldn't be a problem since the BL only deals with the body. Everything else should be stock height underneath like brake lines, fuel filler, ect...
Old Jul 12, 2004 | 11:27 AM
the only thing i was worried about was the battery cables
Old Jul 12, 2004 | 11:44 AM
mt_goat's Avatar
Thanks
TJ
I just put a 1" BL on and the only problems I had were unrelated to my Superlift. I had to loosen my steering shaft clamp to lengthen it a little and lower my transfer case shifting linkage (auto tranny). Roger Brown has some great info but I can't get his site to come up, it used to be here http://4crawler.cruiserpages.com/4x4...le/index.shtml
Old Jul 12, 2004 | 11:51 AM
UKMyers's Avatar
I did a 2" on my Runner and just had to reroute the battery cable a little bit to get some more length on the positive side. The neg was fine. Check the brackets for your clutch hardline too. I just moved the bracket down to the lower hole and only used one bolt to bolt it back to the firewall.
Old Jul 12, 2004 | 05:02 PM
mt_goat's Avatar
Thanks
TJ
Here is the new address for Roger Brown's info: http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
