Help: Reinstalling Center Console Interior Trim
Old Oct 11, 2010 | 09:54 PM
cj_rezz's Avatar
Can anyone explain how to get this piece back in it's proper spot. I got it out but cannot, for the life of me, get it back in. Seems like the center console has to be unbolted somehow.
Old Oct 12, 2010 | 05:45 AM
aowRS's Avatar
Lift up the cupholder section and you'll see that your part in question will just snap into place.
Andreas
Old Oct 12, 2010 | 08:59 AM
cj_rezz's Avatar
That's the problem, I can't lift up the cupholder part. I've pulled fairly hard but it won't lift up. Do I need to pull VERY hard?
Old Oct 12, 2010 | 10:48 AM
scuba's Avatar
Undo the screw that you see in the picture and the screw on the other side of the console. Then you can lift the console slightly. If that fails, you might have to hit it with your purse.
Come on, it's not rocket science.
Old Oct 12, 2010 | 11:12 AM
cj_rezz's Avatar
Obviously it’s not rocket science and, unlike some people, I’d rather not get rammy and break ˟˟˟˟. I’ve had those two screws out that you mentioned and the black part of the center console still didn’t move at all. I’ve taken a lot of interior trim apart of several vehicles including this truck.
I’ve never had such a problem getting a piece of trim back in. I thought there was perhaps a hidden clip somewhere that someone could tell me where it was and how to pull on it so that I don’t break ˟˟˟˟. Thanks for your kind words and advice.
Old Oct 13, 2010 | 07:02 AM
Juppers's Avatar
You have to open the center arm rest to remove the cupholder piece. Also, engage the parking brake. Then pull the black plastic piece straight up. It is held in place with 4 tension plugs, like the rest of the dash, no screws.
Old Oct 19, 2010 | 09:54 PM
cj_rezz's Avatar
Got it back in! Thanks!
nebulae87
Aug 27, 2015 02:45 AM
scooba
Aug 25, 2015 09:49 AM
terminator
Jul 27, 2015 07:13 PM
HookahRoo
Jul 20, 2015 07:06 PM
