Remove interior pieces
Old Aug 26, 2010 | 07:49 AM
anniesball's Avatar
I have an '02 4Runner that the trailer box has failed. I see from diagrams that it is behind the plastic interior panel. What is the best way to remove this panel without any damage?
Thanks
Old Aug 26, 2010 | 07:54 AM
waskillywabbit's Avatar
Remove screws if any. Pull off.
Old Aug 26, 2010 | 08:03 AM
clydehatchet's Avatar
cutting torch
Old Aug 26, 2010 | 12:09 PM
Mauzer's Avatar
Just unscrew any screws then pull, they are held in by plastic "snaps" so be gentle, also, most pieces interlock so if its not coming out look to see if it is overlapped by another piece. or...BFH
Old Aug 26, 2010 | 12:29 PM
piperoo's Avatar
Take out the screws on the trim piece when you open the back hatch. Unscrew the screw that is in the bracket above on the rear of the panel...then it should pop off.
Drivers side, fyi. You can get a replacement on Amazon for about $30 or so that you will connect to the other side. Really easy.
Old Aug 30, 2010 | 09:30 PM
Ron Helmuth's Avatar
you have to remove the rear trim pieces at the door top (roof) and bottom (carpet). The top is a bit tricky because of the light-take your time and you will see how they all overlap. The side trim jumbo pieces in the cargo area are those pop in fasteners. The piece pulls straight out but the fasteners slide in the trim-so if they stick to the body remove them and slide them back into their grooves.
You even have to remove the rear door sills plate trim to give everything room to move around. And the cargo cover bracket squares.
Hopkins sells on Amazon and is plug and play to the taillight assembly but will require both sides trim to be removed. You may choose to go one side only and splice in. Just keep track of your wire colors and test everything out before you put the vehicle all back together. Trust me on this....
A simple 4 pin tester will help verify it's on the vehicle side and not on the trailer side where you are having the issue. Lastly while you are at it-the 4 pin LED sold also by Hopkins is nice piece of visual reference for any future towing hookups. Relatively easy to splice in instead of just a plain 4 pin that tells you nothing at a glance.
Detailed pics at my Facebook link. Trailer converter or taillight converter is a search topic.
Can't wait to see this 7th injector setup.
Old Sep 1, 2010 | 08:59 AM
Ritzy4Runner's Avatar
Thanks
Not totally sure what this is but if you need to remove the interior rear panels this is what I did during my DVD install.
This is along the same route that Ron described, but if you need to completely remove the panel you will need to go a few steps further. I recommend the followingitems you will need to remove;
1) the interior light at the lift gate
2) remove the upper trim panel that the light goes into.
3) remove the liftgate scruff plate.
4) remove the passenger door scuff plate screws and pry the plate up. Be careful not to damage or break the screw posts in the scuff plate.
6) remove the cargo cover mounts.
7) remove the upper screw securing the rear cargo cover to the overhead, this is near the lift gate.
8) begin removing the rear panel starting at the rear passenger door working your way to the rear liftgate. Lift the edge enough to get your fingers under it and lift outward. Be sure to be careful with this step as there is a standoff behind the cover that hooks into a sqaure hole in the fenderwell. If you are not aware of this you can damage your panel.
This is the caution I mentioned:
9) I would recommend laying the rear seats down so you can lay the panel over so as to get at the rear areas and not have to remove the seatbelts.
10) to make it easier I would disconnect the wires/connectors going to your rear 12vdc oultet.
You should have free and clear access to the rear tail light cables/harness to install your trailer light box. Installation is just the reverse. If you need to remove both sides, then repeat the removal of the applicable pieces on the left side. Hope I didn't forget something and also that this helps you to get to the rear lighting harness
Old Sep 3, 2010 | 09:09 PM
ritzys excellent descripts and detailed photos should be their own sticky:
"How to remove 3rd gen cargo area trim pieces"
Old Sep 16, 2010 | 06:58 AM
piperoo's Avatar
Nice pics!
I didn't have to completely remove the side panels to replace my trailer stuff...but it would have helped!
rusty904
Mar 27, 2017 05:20 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
GeoRoss
Jul 24, 2015 03:03 PM
HookahRoo
Jul 20, 2015 07:06 PM
crashburnoveride
Jul 10, 2015 06:39 AM
