Tranny Differences
Old Sep 12, 2010 | 05:02 AM
coonhound130's Avatar
Tranny Differences
In looking for a transmission for my 99 4runner I found that there is something different between the pre 5/99 and after5/99 made 4runner trans . Was told by one place it is just a wire harness that I could cut and splice and by another that it would not work . Mine was made 5 or 6 of99 and I can't find the later trans no where in my state . So if I get the earlier version will it work ? Thanks
Just need to get thhis figured out so I can get it fixed to haul the 2 horses to rodeos until I find the right truck for the right price .
Old Sep 12, 2010 | 05:54 AM
waskillywabbit's Avatar
So yours is a post 5/99? And there are none in your state? Where have you checked?
:wabbit2:
Old Sep 12, 2010 | 07:59 AM
Correct , I have called everyjunk in the phonebook and all that I could find . I live in Tn .
Everyone I found was a pre-5/99
Old Sep 12, 2010 | 08:49 AM
You need to check the online junkyard stuff, as they have lists of junkyard inventories and you can search by state etc.
:wabbit2:
Old Sep 12, 2010 | 08:55 AM
Already done that . Nothing came up within driving distance and not paying high shipping from out of state . Thanks
Might just try and fix the one in it .
Old Sep 12, 2010 | 08:57 AM
You check Grahams in Shelby County, AL? They have a ton of Toyota/Lexus stuff.
They are high, but they would be a good bet to have it.
:wabbit2:
Old Sep 12, 2010 | 09:40 AM
TheDurk's Avatar
How many '99 tranny's were made post 5/99? I got one of the last '99's available in June '99 (2000 models were coming in the next few weeks and there was a sale) and it was built in March. I bought it literally off the truck--they were still unloading it when I signed the papers. (I really wanted a manual). By June, I would think all transmissions produced were going in to 2000 models. It doesn't make sense to change a design for a week or two of production.
Why would you be unsure if it was made in May or June? Can't you just look at the data plate? What does it say? If they did change that late in the year, you'd think it was just early adoption of the 2000 design. Won't a 2000 work?
Old Sep 12, 2010 | 12:28 PM
mine is a 6/99 and every shops even dealer says that a pre5/99 trans is different , not sure why they change it like that but they did . I am having one hell of a time finding one . I found a bunch but all are the pre 5/99 made and they claim it will work with some rigging of a harness or conector . Not sure on that so that is why i posted to find out if it is true . if it will work i can drop one in with a 6 month warranty for about $300 total
Old Sep 12, 2010 | 02:13 PM
Kerby J's Avatar
are they different even with the same transmission code or are they different codes?
Old Sep 12, 2010 | 02:17 PM
different trans code
Old Sep 12, 2010 | 05:03 PM
FogRunner's Avatar
The transmissions from the 01 and 02 4runners are totally different. Instead of having a kick down cable they are totally controlled by the computer. Just FYI if you run across one.
FOG
Old Sep 13, 2010 | 12:00 PM
brian2sun's Avatar
I think '99 and '00 Limited 4runners had different trannies than the SR5s, Highlander/Sports, and base models. The '99/00 Limiteds had the multi-mode 4x4 system but the other trim models from those years did not. Not entirely sure if the difference was all in the t-case or not, but I would guess that the trannies are different too.
Old Sep 13, 2010 | 02:00 PM
J2F42C's Avatar
Try Blevins Auto Enterprise in Roan Mtn. (423)-725-2203. I know someone who has gotten t100 parts from there before.
I do want to see a pic of the 4 runner pulling the horse trailer. If anyone was a candidate for an external tranny cooler, you must be since having to tow at least 5000 lbs+. And the 4 runner is only 2 inches longer than the minimum required wheelbase of 114 inches to tow a horse trailer. Just think diesel.
Old Sep 13, 2010 | 02:22 PM
Will get some pics next time I hook it up if I do . I am currently in the process of trying to buy another 1ton deisel now , but might take a few months because I am getting alot bigger trailer for the weekend long trips to rodeos now that my 9 year old is starting to rope also .
Old Sep 13, 2010 | 02:23 PM
I will say that the $runner does pull it real good for a v-6 , on flat road you can't even hardly tell the 2 horse is back there
Old Sep 13, 2010 | 07:46 PM
J2F42C's Avatar
That is impressive and good to know. I pulled a 2 ton dual axle horse trailer across Virginia three times with a Surburban with a 454 in it. Still not fun. My uncle has pulled my niece in SC all over the South with his Cummins 5.9 Dodge. Never failed him once after 236,XXX miles
Try Underwood Auto Salvage right outside of Knoxville. (866)-922-7499. A friend, who works at Gander Mountain, got a transfer case there while studying at UT. Also have a friend in Clarksville, I'll see if he knows of a yard that may have one....
Old Sep 14, 2010 | 03:00 AM
I am looking at either another 7.3 Powerstroke or a 24valve Cummins as my next rodeo hauler . I sure miss my last one .
Thanks
Old Sep 27, 2010 | 01:56 PM
ToyotaTwinz's Avatar
anyone know if a 2001 toyota tacoma tran pan fits a 1996 toyota tacoma ?
..... i put the 2001 pan on ... and the rod on the pan is about 2 inches shorter than the rod on my older pan (96) ...
same shape and size of pan ... just the rod is shorter.....
Dieselmann
Feb 19, 2019 02:57 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
norcal98
Aug 10, 2015 06:20 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Iceman4193
Jul 15, 2015 04:48 PM
