SAW's and OME
Old Apr 27, 2003 | 10:52 AM
Ducky's Avatar
SAW's and OME
I originally was going to get all OME coils and springs... could I get SAWS in the front, and a OME coil and spring (prolley HD's) in the rear? if so, do I still need the cornfed 1" spacer, or does the SAW's eliminate the need for the spacer to make my 4runner level, like I would with the OME setup?
Ducky
Old Apr 27, 2003 | 11:45 AM
Bighead's Avatar
No problem running the SAW/OME combo. There are several guys here that run that (Schaefer, phong and Darren off the top of my head). You won't need the spacers with the SAWs since it is adjustable. Just dial it to the height you desire. One of the big issues is the price. OME/spacer is a lot cheaper than a set of SAWs.
Check out the Toyota SUV Suspension Lift Collaboration from ODW. The article has feedback on several different suspension setups.
If you haven't done so yet use the search function. All sorts of good info available.
Old Apr 27, 2003 | 12:14 PM
RTdawgs's Avatar
OME coils $125
OME struts $200
Spacers $130
Shipping $35
TOTAL $490
SAWs $675
thats only $185 difference, i dont consider that a lot.
IMO, do it right the first time.
Old Apr 27, 2003 | 12:55 PM
Bighead's Avatar
I stand corrected Ryan. For some reason I thought the price difference was more.
Live and learn...
Old Apr 27, 2003 | 01:26 PM
Ducky's Avatar
costs
It is a bit more....
SAWs for 675.00 is for just a pair.... fronts...
you still have to get coils and shocks on the rear... dif drop..
From my calculations... the saw config with OME rears are a bit more than just a OME setup... but i guess prices vary... considering a cornfed spacer is about mid to upper 100's... im sure the figgure is around 400-500 difference... I could be wrong since im not looking at my excel spreadsheets, since im not at home.
Ducky
Old Apr 27, 2003 | 03:07 PM
RTdawgs's Avatar
my comparison was for front only, either way you gotta spend $250 for rear coils/shocks.
Old Apr 27, 2003 | 03:52 PM
Mad Chemist's Avatar
I'd beg to differ a bit on the prices- I'm pretty sure the front OME set-up is ~225. That's what I paid for my rear set-up, and the prices I saw for the front from Central offroad were in that same range. The spacers are only that expensive if you go with Corn.- Revtek 1" spacers are significantly cheaper, and OME trim packers can even be used to level out the front. Shipping isn't really an issue- Ducky can pick up the parts directly from Central Offroad in Washington, or pick them up directly from ARB in Seattle, which is what I did for my parts. The SAWS option up front is going to end up being much more expensive.
With that said- the adjustablility of SAWS are nice- if you decide to add a bumper, winch, etc. which is going to add more weight to the front, you won't have to worry about buying another set of coils to get the front lifted again. From what I understand, the ride is pretty sweet as well.
I'm in the same boat as you Ducky. I really like the look of the ARB bumpers, and all though I won't be getting one for a while, I'm thinking about going with the SAWS for that reason. My OME set-up for the rear is sitting on my balcony, waiting for me to make up my mind!
Old May 26, 2008 | 06:20 AM
dirtballer's Avatar
Coil Overs and ARB bumper questions
I have a 2004 double cab taco and I'm regualrly running back and forth on a logging trails. Alot of night time critter obstacles and northeast brush so went with an ARB bumper but my front end is sagging. Other than the addition of my new heavy bumper i'm still running TRD stock.
If i only install front coil overs but keep the rest of the stock suspension would that give me the lift i need for the front bumper, give me a more level ride and also give me better suspension for logging roads?
what else would i have to do if anything? Did i just open up a can of worms?
I want to keep it simple so it's good on the road and better on the logging roads
Thanks
s
Old May 26, 2008 | 07:06 AM
crolison's Avatar
i am running adjustables up front and ome in the rear.
Old May 26, 2008 | 07:45 AM
dirtballer's Avatar
I'm new at this so adjustables mean coil overs where i can adjust the collar to level the rig and your running ome shocks or shocks and springs in the rear?
How does it ride? Is the weight of your custom bumper equal to the ARB?
Old May 26, 2008 | 08:35 AM
crolison's Avatar
Yeah adjustable is a coilover, where you can crank them up or down to adjust the ride height. I am running ome 891's in the rear, and bilstein 5125's. The front bumper weights a tad less than a arb, but once i get a winch in there it will be heavier. It rides nice right now, bumps are alot smoother than stock.
Old May 26, 2008 | 08:51 AM
dirtballer's Avatar
Can i install the front coil overs and wait a few months to do the rear or should i do it all at once?
Old May 26, 2008 | 09:24 AM
crolison's Avatar
You can, but it depends on the coilover how far you can crank them down, or you could ride with the socal look. I ran for about 8-9 months on stock suspension with the bumper on, and the only thing that really sagged was my rear end.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
A2theK
Oct 14, 2015 07:10 AM
Swampwalker
Oct 12, 2015 09:49 AM
justdifferentials
Sep 5, 2015 06:52 PM
