best lift to add 35' tires
Old Apr 24, 2003 | 06:30 PM
nalexander7's Avatar
what would be the best lift to add 35 x 12.5 x 15 baja claw radial tires to a 95.5 toyota tacoma. I figure either pro comp 4' suspension with a 3 inch body lift. A superlift 5' system with a three inch body lift, or a trailmaster 6' system with a 2 inch body lift. Please help i want my truck to have a mean look and not have any rub on my fenders. I am willing to do some trimming if necessary.
:pat:
Old Apr 24, 2003 | 06:38 PM
Flygtenstein's Avatar
Dude, I've got some bad news.....
35 FOOT tires will not fit with that lift!
Old Apr 24, 2003 | 08:26 PM
RTdawgs's Avatar
35' is impossible.
if you meant 35" tires, then the TM kit plus 2" body is pefect. anything less and youre in trouble.
Old Apr 24, 2003 | 08:42 PM
L33T35T 4Runner's Avatar
35 foot tires arent impossible
you can do anything you set your mind to
Old Apr 24, 2003 | 09:26 PM
Del's Avatar
Del
Those "Earth Movers" got sum pretty big tires.
Old Apr 25, 2003 | 06:43 AM
beachtaco's Avatar
since everyone busted you on the 35 foot remark, i'll give you an answer.
your lift depends on the width of wheel you use. if you use 8" wheels, then you can bearly clear with 6" of lift. for 10" wheels, i suggest atleast 8" of lift. you had still rub on full lock turns and off road. both, you have to hammer the pinch weld down on the inner front fender wells.
i had 12" of lift with 35" and i could still rub at full flex.
btw, superlift does not make a lift for tacoma. it's only trailmaster and procomp. fabtech is suppose to come out with a kit too but it's not on the market.
Old Apr 25, 2003 | 07:02 AM
metal22lica's Avatar
beachtaco...you have any pics of your rig?
Old Apr 25, 2003 | 07:05 AM
CTB's Avatar
CTB
Click on the "www" link at the bottom of his post.
Old Apr 25, 2003 | 07:49 AM
beachtaco's Avatar
yeah, check my website out at www.geocities.com/beachtaco
also, check out http://forums.delphiforums.com/tacomaterritory/messages. do a search first before you post. you should find more info about 35" and lift.
Old Apr 25, 2003 | 12:42 PM
holy ˟˟˟˟..........haha........i mean 35'' tires......sorry......thats funny...........so should i go 8'' total lift.....i take it pro comp 4'' with a 3'' body lift wouldnt be enough?
Flying91
45
Apr 11, 2024 04:39 PM
82yodahickman
34
May 16, 2017 01:00 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
