Tell about the advantages of adding a locker
Old Mar 9, 2004 | 01:59 PM
redvet's Avatar
Please telll me the benefits of a locker.
Better driving in snow with my Pre Runner?
I assume a locker gives you positraction.
Brand names?
Cost for parts and install?
Any disadvantages?
Old Mar 9, 2004 | 02:08 PM
HaveBlue's Avatar
Brand names?
Any disadvantages?
You don't want a locker on snow or ice. It will greatly compound any out-of-control situation.
A locker and positraction are two different beasts. Positraction is another name for limited slip. Limited slip is exactly what it sounds like. It limits the amount of differential slippage while power is being applied. A locker locks the differential and prevents both wheels from spinning independently from each other.
ARB, Aussie, and Detroit are brands of lockers. Your Pre-Runner didn't come with a locker? I thought all Pre-Runners came with them. Or is this a conversion project? You could swap in an electric locker. A few on the board have done it. It will cost a little less than an ARB which will run you about $1800 start to finish.
Old Mar 9, 2004 | 02:16 PM
redvet's Avatar
Thanks for the very informative reply,Alan.
Well a locker wouldn't be a benefit to me in snow.I thought a locker was posi(limited slip).
Now that you mention it I have the truck a few weeks and don't know if has a locker or not.I doubt it because I don't see any buttons anywhere other than on the shifter.
Which I would assume is the overdrive on/off button.
Old Mar 9, 2004 | 02:27 PM
GRNTACO's Avatar
I disagree on the snow part. A locker can help you in the snow if you are wheeling on trails or Forest Service Roads. I would agree with causing trouble on freeway driving in the snow and ice.
Old Mar 9, 2004 | 02:31 PM
redvet's Avatar
Not too trails or Forest Service Roads in NJ.
I'm looking for on road snow use benefit so I'm screwed.
Old Mar 9, 2004 | 02:37 PM
GRNTACO's Avatar
Yeah, I must have missed that part. Personally I don't see the advantage of adding a locker.
Old Mar 9, 2004 | 02:44 PM
redvet's Avatar
You're right.
I guess what I really want is limited slip.
Old Mar 9, 2004 | 04:35 PM
KING's Avatar
If you have a locker, there should be a button to the left of your steering wheel, right beside the dimmer light knob that says "RR DIFF LOCK."
Old Mar 9, 2004 | 04:48 PM
anthony1's Avatar
a locker would help if one tire is stuck and the other tire is not.
I used to have Detroit Locker and didn't do too well in the snow. I was sliding a lot on the curve that have angle. The guys that don't run locker just goes around the corner slowly. I had to speed up so that my rear won't side toward the inside of the curve. I live in So. CA so snow is not a big problem.
I see benifit of having a switchable locker that can help in some situation. I know you don't have 4wd but if you do, having locker in the front during straight road would help more than the rear.
I've since switch to cable converted toyota elocker in the rear and ARB inthe front.
Old Mar 9, 2004 | 05:18 PM
Flygtenstein's Avatar
Do you wheel?
Auto lockers in 2wd rigs are nothing but a waste of time on the street.
A manual locker may help some, but the cost benefit curve would likely not balance.
A locker locks both rear axles togther. Auto lockers do it only under load. Manual lockers do it until they are disengaged.
Locker makers, Detroit, Lock-Right, PowerTrax, EZ-Locker, ARB, Aussie, E-locker, OX-Locker, and that is about it.
Search, there is some info about this since the question is not new.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
bradahman
Oct 1, 2015 09:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
