Outer Tie Rod End issue since freehub swap...
Old Feb 23, 2010 | 09:22 AM
amorphous's Avatar
I guess my initial question would be:
are Tacoma OUTER tie rod end shaft bigger at the bolt that goes thru the spindle?
I had the manual hub conversion done with Tacoma spindles...
now, i'm have an issue getting the truck to pass inspection because of "too much steering wheel play" - which is located in this outer tie rod end moving too much in the spindle. I torqued this to spec...and for the life of me can't figure it out....UNLESS...
am i putting the wrong outer tire rod ends on?
any insight would be great!
-aaron
Old Feb 23, 2010 | 10:57 AM
crolison's Avatar
technically you didn't even ned to touch your outer tie rods.....
the only thing needed touched was the upper ball joint
Old Feb 23, 2010 | 11:03 AM
amorphous's Avatar
correct - upper all the way down to the lower were replaced.
That's not the issue - the issue is in the outer tie rod end - the LEFT one has buncho play and is causing steering slop (basically you can move the wheel a good 4-5 inches before it turns the wheels)
they are brand new. rack is solid, bushings, etc....the issue is obviously RIGHT there D/S outer tie rod end....
i guess i'm just doing to crank the Outer d/s down a whole bunch - past torque spec?
Old Feb 25, 2010 | 04:23 AM
amorphous's Avatar
found out the answer:
YES - there IS a different diameter end to the part of the outer tie rod end that goes into the spindle!
FYI when swapping 3rd gen Taco and 4R parts!
bigjstang
Jun 2, 2025 03:56 PM
jasonty
41
Dec 23, 2018 01:00 PM
May 20, 2016 10:27 AM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
