Towing with your 3rd gen.
Old Feb 25, 2010 | 05:13 AM
NickP's Avatar
Hello all, i believe this is my first thread start. Anyways. My question is about towing with your 3rd gen. I see alot of people towing smaller stuff around with them (dual snow mobiles, dual ATV's, ect) and the rear suspension seems to squat really bad. Was wondering what i could do to solve some of the squat issue, and make the 4rnr more "tow" ready
In the future i plan on towing a featherlight one car trailer and my 2500lb car. on rare occations. And my ATV with a small trailer often.
Thanks for the help guys
FYI i plan on sometime doing a 3" lift to it. so if there is a lift that will help with this, feel free to share
I also am already running 33" tires on my Limited. (17's inch rims)
Old Feb 25, 2010 | 05:41 AM
waskillywabbit's Avatar
Lift with new coil springs and a trailer hitch with the proper drop and it shouldn't sag.
Old Feb 25, 2010 | 07:44 AM
Potomacduck's Avatar
I have a '99 limited.
I towed a Bass Tracker boat (1,800 pounds) for 200 miles last year. Lot of hills.
It sucked
Old Feb 25, 2010 | 07:46 AM
canterm's Avatar
May also want to look into airbags. I am not sure how much they cost, but they came on my 3rd gen when I bought it from the previous owner and it will eliminate the sag when i tow.
Old Feb 25, 2010 | 08:07 AM
cackalak han's Avatar
I'd invest in a transmission cooler, good ceramic brake pads, synthetic diff fluid (75w-90), and maybe airbags in the back. Are you going to be going up any mtn passes? Might be a bit of a struggle with 33's and a trailer, if you're not regeared.
Old Feb 25, 2010 | 08:39 AM
AlexJet's Avatar
Usually around 150-200 range for a set of 2 airbags
As of towing, I towed 10'000 lbs trailer with my 4th Gen (V6 version) and I think my 3rd Gen is capable of making to about same level, may be a bit less.
Old Feb 25, 2010 | 09:24 AM
Firefightertaco's Avatar
wow dude u pulled a 10000lbs trailer with ur 4th gen, that's pretty dangerous, i hope you had trailer brakes
Old Feb 25, 2010 | 09:31 AM
I agree with firefighter. That is dangerous even with trailer brakes. I recommend not towing anything right at the tow limit, much less DOUBLE. If you towed that thing for an extended period of time, I'd take a close look at your drivetrain, frame, etc. 4Runners were not meant to tow that much.
Old Feb 25, 2010 | 10:31 AM
pdyebrasil's Avatar
If you're looking at doing a 3" lift, I would fully recommend a Sonoran Steel lift. I have system 7.2 and even under a fairly heavy load it doesn't sag much. Steve at Sonoran Steel would be more than happy to answer any questions regarding towing... I don't tow much when I do. He does very high quality work, and as far as lifting 3rd gens goes, you couldn't do much better.
Old Feb 25, 2010 | 01:21 PM
DailyDrive's Avatar
I towed 45000lbs on 62" tires and with 24" of lift.
Old Feb 25, 2010 | 01:28 PM
Do you ever have anything useful, much less correct, to say?
Old Feb 25, 2010 | 01:30 PM
yeah same here, i put a flat bed on my taco with a 5th wheel in the back and i tow semi trailers through the Tennessee mountains, that tundra brake upgrade is awesome
Old Feb 26, 2010 | 01:03 AM
wyoming9's Avatar
Red face
I have noticed that the 4Runners have a lot softer suspension thus when you put anything on the back they really sag even with new stock springs .
My 2000 tacoma came with a factory towing package and with the same piece of equipment does not sag at all.
If towing is only a once in a while thing I would go with airbags for when you need them.
Old Feb 26, 2010 | 01:59 AM
rocket's Avatar
Obviously you didn't search.
There's 12 pages total..or 200+ threads about 'towing' and 'tow' in this sub-forum alone. Some are a recent few pages long with plenty of info. Please start there or here. Thanks!
And for the love of everything sweet, it's called a 4runner! Nothing else.
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
