98 4 Runner Ecu --Mods ??
Old Feb 6, 2010 | 02:38 PM
dem0nk1d's Avatar
so i'm going to be venturing into the 3.4 swap into my 92. I have the full wiring harness, engine / all accessories, and ecu. The ecu is a manual 4x4 5vz btw.
The first thing i did when i got back from the junk yard is threw the ecu on the work bench and cracked open the case. The only thing that catches by eye is the factor 2x5 connector on the board which needs to be soldered on. I'm thinking this is some kind of raw data serial connector for the yota techs.
Does anyone know what it is? And can possibly shed some light on this. I would think that if i knew the pinouts of that connector i would build a simple rs232 interface to do some simple data logging.
let me know...
Old Feb 6, 2010 | 02:40 PM
dem0nk1d's Avatar
http://toyota.kgbconsulting.ca/media...php/5VZ-FE_ecu
here is a link a snapshot on the board. notice the 2x5 connector "10 pin" 2 rows of 5.
Old Feb 6, 2010 | 02:48 PM
mastacox's Avatar
There's no need to tap into the board for data logging, you can just use the OBD-II interface which has all of the pertinent engine metrics.
Old Feb 6, 2010 | 02:53 PM
dem0nk1d's Avatar
but what about possibly re-flashing or reprogramming fuel / ign maps on the fly. i know serial data transmission over the wire would be slow as a terrified snail. but it would be a possibility to interact with the onboard rom.
data-log -> adjust maps as needed then reflash rom with new data.
MTLroadierunner
Jul 15, 2015 12:58 PM
tpd143
Jul 7, 2015 09:06 AM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
