Surging under 3200RPM
Old Feb 13, 2010 | 08:00 AM
yamagirl's Avatar
Not sure how else to explain this one but here goes. Every day I go up a long grade and manually shift out of OD after hitting the bottom 1/3 of the way up otherwise it constantly hunts for the right gear. After shifting out of OD i maintain speed but it always seems under 3200 RPM its sluggish and feels surgeing,then literally like a turbo kicking in when we hit 3200 RPM or 70 or so it takes off like it gained 50 HP. It it not shifting or unlocking the converter either as I see no instant RPM change or feel a shift. Any ideas? This is on a 98 V6 auto 4wd runner.
Old Feb 14, 2010 | 12:55 PM
eddieleephd's Avatar
the power band in these trucks is between 3200 and 4200 rpm you should just try to be there when you hit it!!
Old Feb 14, 2010 | 04:58 PM
LarsDennert's Avatar
Sounds like a dirty MAF sensor but the motor also doesn't come on the cams until 3000 as the other poster mentioned.
Old Feb 18, 2010 | 06:25 AM
kawicowboy's Avatar
When was the last time you changed the plugs and wires
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
Ditch Doc
Oct 27, 2015 03:20 PM
Gurr
Sep 12, 2015 09:51 PM
PBRaddict#1
Aug 22, 2015 11:34 PM
