97 4runner needs ring and pinion?
Old Feb 13, 2010 | 08:48 AM
bluescoob's Avatar
I have a 97 4runner with 193k currently..I have some bad whining when accelerating coming from the rear. I have been told its the ring and pinion from a good friend of mine. So obviously it needs to be fixed asap. Just mainly looking for some advice from you all as what to do. What set I should buy new or used or maybe you all think it may be something else. This is my first 4runner and learning these vehicles as I go. Thanks in advance Tony
Old Feb 13, 2010 | 12:26 PM
bluescoob's Avatar
not much help today
Old Feb 13, 2010 | 12:59 PM
waskillywabbit's Avatar
Have you had it professionally diagnosed or your friend just thinks its your R & P? I'd be certain before I assumed I diagnosis on sounds alone.
In the 4 hours between your posts did you do any research?
Old Feb 14, 2010 | 12:50 PM
eddieleephd's Avatar
well if you get this done you will need to take it to a rear end or gear shop to set it up because it is a very important part and will screw it up if not done properly!!!!! I work on my own truck for every thing but this and alignment easier and better to have a pro do it and you get a warranty!!!!
Old Feb 14, 2010 | 12:53 PM
Oh yeah if you do not know your gear set you will nee to go here!!!
http://ttora.com/wiki/index.php/Gear_Codes
Old Feb 14, 2010 | 05:01 PM
LarsDennert's Avatar
And stay away from Genuine Gears brand. Get Precision or OEM. The carrier might just not be set up and need a rework too.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
tobylab
Jan 18, 2016 07:06 PM
tobylab
Jul 12, 2015 12:53 PM
Edionne13
Jul 9, 2015 01:59 PM
