99 4Runner V6 smoking on startup?
Old Aug 20, 2008 | 04:46 AM
Jordan Petry's Avatar
I just went to start it and it was smoking a whole bunch... I looked under the hood and I checked the oil, that was fine but then I saw the coolant reservoir was empty. It wasn't empty a few days ago when I replaced the timing belt, water pump, etc.. I did notice that the thermostat had a slight leak around it. Nothing serious just a few drops but I can't imagine that leaking out the whole entire reservoir. That also doesn't explain my smoking problem... The only thing that I can muster up is that it has a blown head gasket. It only smoked on start up not while driving. Any ideas?
Old Aug 20, 2008 | 05:07 AM
Reverend's Avatar
What color is the smoke?
Old Aug 20, 2008 | 12:13 PM
The smoke is white... I just went to start it up and there was absolutely no smoke and the reservoir was as full as it was when I filled it up this morning after I noticed the smoking issue. The engine was not warm when I just started it, it had not been started for about 9 hours. BTW when I started it the first time it was about 70 degrees outside and now it is about 80 if that makes any difference.
Old Aug 20, 2008 | 12:44 PM
BigBallsMcFalls's Avatar
white smoke is coolant. u r gasket bound
man up and taste a wet drop from your exhaust
(spit it out) if sweet (which it will be) you are in major gasket repair land
Old Aug 20, 2008 | 06:27 PM
Yea I'm pretty sure it's the HG... Can I drive it like this for a while? I drove it about 50 miles today and it didn't leak at all. I really can't afford to replace the head gasket this soon but I am willing to spend $10 a month on antifreeze.
Old Aug 20, 2008 | 07:52 PM
you are asking for sudden engine seizure to drive on a known bad gasket
if it lets go you will have to pull over and stop immediately. it is likely doing damage right now. water does not lube as well as oil
Old Aug 20, 2008 | 08:20 PM
BajaRunner's Avatar
You could probably do a head gasket no problem. Its what, $30 or $40 for the gaskets?
Old Aug 21, 2008 | 04:20 AM
It hasn't been leaking any coolant at all recently though?
dzldust
7
Oct 6, 2015 05:39 AM
Boomer8404
Sep 10, 2015 09:01 AM
ErikZ1220
Sep 10, 2015 04:53 AM
joeynational
Sep 5, 2015 01:54 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
